Just did my 1st 308 oil change - how tight for the filter and plug? | FerrariChat
Discussion in '308/328' started by fchip, Apr 1, 2010.
  1. fchip
    fchip Formula Junior
    Jul 15, 2007
    428
    Raleigh, NC
    Chip G
    Couldn't find any specifics on how tight to make them so I snugged them pretty good. I guess the obvious answer is that if I see a leak at the filter or at the bottom of the pain around the plug then it is not tight enough, true?
    Chip
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    Normally a new crush washer is installed at the drain plug.....
    No need to get crazy on the filter either, most of them have it on the side, "1/2 turn after gasket meets the surface" or something to that effect.....
  3. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    You are braver than I am. I would be afraid to do it myself with the oil filter being over the clutch.
    PDG
  4. CarreraScott
    CarreraScott Formula Junior
    Jan 30, 2004
    592
    Charlottesville, VA
    Is the crush washer something you can just pick up in Autozone/Pep Boys? If so any size/kind specifically? I have a several oil filters for future changes but don't think I have any crush washers for the drain plug... thanks.
  5. BillyD
    BillyD Formula 3
    1,829
    Pacific Northwest
    Bill
    Tell me about it! I had changed my oil 1/2 dozen times & never had any oil leak out of the filter. That was til the time I had the timing marks cover off & an ounce or two of oil leaked onto the clutch causing it to fail.
    Bill
  6. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Oh, come on, guys. Put a piece of plastic down with some absorbant towels on top and under the filter base, and unscrew the darn filter. This is NOT a big deal. It's a dang car. If you've let the filter drain back, there should be very little oil that comes out of it, and any that does should easily be caught by the towels.
  7. 11506apollo
    11506apollo F1 Rookie
    2,707
    Tx Co Ca
    what type and where to get the proper crush washer guys????
  8. Glen_Lloyd
    Glen_Lloyd Formula Junior
    Dec 13, 2003
    785
    Lloydminster AB
    Glen
    If I had to bet I would say Ricambi. I hope you are using an UFI or Baldwin filter for the anti drain down feature.
  9. fchip
    Jul 15, 2007
    428
    Raleigh, NC
    Chip G
    I got 3 UFI filters from SportAuto when I picked up the car and Tom made sure I had a new copper crush washer taped to each filter box. So that went fine. When I pulled the old (Fram) filter after letting every thing drain for 20 mins there was barely a drop or two that came out. I just put paper towels around the area and had a zip lock baggie ready to drop the old filter in. I don't think I spilled anything anywhere. Just wasn't sure how tight to make it, but based on Big Tex's comment I think I got it right.
    2 hours and a little dirt everywhere I have a happy horse with some new redline in her and a proper UFI filter on top.
    I am struggling to make sure I have her filled up propoerly though. Hard to read the dipstick when the oil is that clean. I put 2 gallons in plus approx 1/4 of another gallon. I will check it again tomorrow.
  10. fchip
    Jul 15, 2007
    428
    Raleigh, NC
    Chip G
    By the way, oil temp hovered around 200-210. (It is 80 degrees here today.)
    Water temp was mid line (190?)
    Oil pressure was 75-80 with tach at 3500-4000 cruising.
    All seemed OK. Hopefully I have enough oil in her.
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    Sounds 'happy" to me....the only other thing to know is the two marks on the dipstick are 'two quarts' apart.....
    Ptama10 likes this.
  12. fchip
    Jul 15, 2007
    428
    Raleigh, NC
    Chip G
    Thanks Boss. I have had lot's of cars and I can normally handle a dipstick, but I swear the level is either just at the bottom of the stick or at the top of the normal line. Hard to tell what was smudged on and what the real level is. I am going to get a little quart measurer and confirm that I put a quart in her from the gallon container I have. If I didn't put enough in I am going to add and see if the reading becomes more obvious. If anything she might be a touch low.
  13. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
  14. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
  15. BigTex
    79,386
    Houston, Texas
    Bubba
    Go run it awhile and it'll darken........on your later car the marks may be different, do you have the Books????
  16. fchip
    Jul 15, 2007
    428
    Raleigh, NC
    Chip G
    Yeah, the manual says 9 quarts (10 liters) so I think I am pretty close.
  17. f355spider
    f355spider F1 World Champ
    18,047
    The NAPA crush washer works, but the ones from Ricambi or the FNA dealer are a bit thicker, and have an easier to detect "give" when they yield or crush. I just always be sure to buy a few each time I buy some filters. (get a couple extras in case you lose one or need to help a buddy) :)
  18. f355spider
    18,047
    #18 f355spider, Apr 1, 2010
    Be sure you are checking correctly per the owners manual. It does very a bit by year, but usually you need to wait 5 minutes or so, with a standard wet sump 308/328. I agree checking is kind of confusing, and the reading seems to vary depending on which side of the stick you read from....
  19. Glassman
    Glassman F1 World Champ
    Get yourself a pair of $3.00 magnifying glasses. They come in very handy.
