Just got my PPI info-help please | FerrariChat
Discussion in '348/355' started by James-NZ, Jul 25, 2007.
  1. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    So my PPI has been completed and i have just been faxed the results, other than a few minor things like cd player and cigar lighter not going, all looks ok, EXCEPT the compression check:
    The car is a 1997 355F1,
    1) 180
    2) 160
    3) 170
    4) 175
    5) 170
    6) 175
    7) 170
    8) 180
    readings are in psi.
    so, let me hear it, is number 2 a concern? we did not do a leak down at this stage but i can have one done if it will help and, not sure im happy with these figures, well happy with them except cyl 2, seems abnormally low. is there any point in getting a leak down done? or do i walk away from it?
    also there was an error showing "thermo couple cat protection" all the minor issues have been taken care of already, so its really the compression that is my concern.
    what is the ideal compression for the 355?
    All help is appreciated.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    You should actually have the leak down done in addition to the compression check.
  3. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Numbers 2 and 7 are the first to go.
    If it priced accordingly, do the leak down, if not, walk.
    Dave
  4. op360
    op360 Karting
    Mar 16, 2006
    69
  5. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    Thanks, I had been following that thread but didn’t want to hijack it.
    So 220-230 psi? this one is no where near that, to be honest I have never seen any compression tests on any car get that far over 200 psi.
    Are the 220-230 psi readings what I should be looking for on a 355?
    Once again, any help is much appreciated.
  6. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    That's about what I had (220+). But have seen many cars in the 180-200 range. Honestly unless this car is a must have for you (your ideal color, body style, mileage, etc) I might walk away with a 160 - UNLESS it was priced accordingly.
  7. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    It is the ideal one in some ways, I do not want a red one (runs and hides in the corner) and I don't want spider, so in New Zealand that leaves me with the choice of about 6 cars. Out of these, one has had a bad accident (I took photos at the scene) and the one I am looking at is the only one on the market at the present time. It is at Ferrari NZ and the price is not cheap for a 355, I would go as far to say it is top dollar at $179k nzd. I have seen them as cheap as $159k nzd but that was about a year ago and I was not in the position to purchase at that point.
    I spoke to the service manager at F-NZ he did not seem concerned about the compression at all, he said if the cylinder had a problem it would misfire and he would be able to hear it, well I guess that is correct but I think the low reading might be a sign of things to come maybe?
    hmmm, I have also put a 10k deposit down on it, this is a hard decision, if I choose not to take it, there might be a long wait till the next one comes up, or I might have to shop for other models....and in NZ with my specific requirements (non red, gtb pref F1 etc) this wait might be never ending.
  8. Darryl
    Darryl Formula Junior
    Jan 4, 2006
    410
    Southern California
    Darryl
    Thats why I purchased a 348.
    Darryl
  9. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    you're mean
    leaves us alone
  10. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    If it is priced right, everything could be fixed and you would have a fresh start :)!!
  11. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,611
    Gates Mills, Ohio
    Jon
    He said $179K nzd is top dollar.
    Tough decision, unless the dealer is selling the car and would offer some kind of warranty on the engine. If it was my checkbook, I'd probably keep looking. Can you import a car from Australia?
    As a card-carrying member of the 328 Syndicate, I have an idea though...
  12. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    hmmmm, i love 328's too....
    The dealer is giving me a 12 month warranty, and both the dealer and the service manager have promised to look after me and the car if any problems were to occur. When i speak to them they instill every bit of confidence in the car and in me, they always put my mind at ease.
    I have always wanted to buy my first F car through F-NZ as they have never prejudged me even when i was a 7 y/o boy drooling over the cars, they still let me sit in a F40! and this is why i don't have a problem paying top dollar for the car, so long as it is a good one.
    Some thoughts crossed my mind before, i own a compression tester and it is the type that has the rubber tapered end to fit into the spark plug hole, this probably would not give a spot on reading but for the purpose i use it for it is OK, if the ppi was done with a tool like this, there is a possibility that the reading was not as accurate as it would have been if the tool used had the spark plug thread on it and was screwed into the hole and seated on a seal, (boy am i clutching at straws or what!)
    I cant remember the last time i was in a situation like this, i love the car, it fits my wants perfectly and is in my price bracket.
    If it was to go wrong and it needed valve guides, what is the US cost of doing these, this will give me a ruff idea of the price in NZ, the service manager dose not know how much to do the guides as he has never had to replace them in any of the 22 355's in NZ.
    160-180 psi compared to 220-230 pis is a massive sign of wear is it not?
    should have put a poll at the top, if you looked at buying a 355 and the compression was 160-180 psi,(and at the high end of the price scale) would you:
    1) walk away
    2) just buy it
    3) try to renegotiate the price to reflect the new found problems, or
    4) what is the point in this poll, 160-180 psi is nothing to worry about.
  13. Ricambi America
    Sponsor Owner
    Promise <> warranty. Get the leakdown.
