Just picked up a 458 - question about OEM charger | FerrariChat
Discussion in '458 Italia/488/F8' started by Bluedan, Sep 3, 2023.
  1. Bluedan
    Bluedan Rookie
    Aug 19, 2023
    12
    Erin Parker
    Is it normal for the OEM 458 charger to alternate between the amber (“charging”) light to the green (“fully charged”) light in intervals of about 10 seconds once the car is fully charged? I’ve left my car charging overnight and this morning I noticed the lights alternate, and the green light does not remain lit permanently. The user manual didn’t provide much guidance here. Thanks!
    vraa and rob5819 like this.
  2. ONEOFEW
    ONEOFEW Formula Junior
    Jan 19, 2006
    835
    LA
    Steve
    Alternating every 10 sec isn't normal, oem CTEKs are known to fail, so are batteries. You need to get it checked out.
    I would suggest disconnect the CTEK until you sort it out.
  3. victorc31
    victorc31 Rookie
    Jul 18, 2023
    26
    Victor C
    I got mine (458) a few weeks ago with the oem red charger. After turning green it stays green. I got in the car a couple weeks later and noticed it went to amber for a few minutes when I got out. Then it switched back to green and stayed there within the hour. It was interesting after a 3hour drive it wasn’t green from the start…. The dealer told me the battery was tested and passed.
    purexotic likes this.
  4. Eatpies99
    Eatpies99 Karting
    Jan 11, 2022
    50
    Chris Tomlinson
    Mine was like that. After a few months it wasn't really charging the battery properly. Bought a new ctek and got the adaptor to fit the car off eBay. No issues since
    430jm and vdm9 like this.
  5. VelocityTexas
    VelocityTexas Formula Junior
    318
    North Texas
    Bryan
    As soon as you open the door you can hear the car come alive thus a draw. The charger kicks in as there is an amperage drop. Normal for the light to change.
    luvair and DefunctNeurons like this.
  6. luvair
    luvair Formula 3
    1,595
    Agree, same as mine that works properly. Also, even after a long drive, you mentioned 3 hours, once I plug in the maintainer, the light isn't green. It takes a little time for it to turn green, that is normal too.
    Congrats, on your 458, it is awesome.
    DefunctNeurons likes this.
  7. Sargepug
    Sargepug Formula Junior
    Mar 23, 2020
    888
    NYC
    Congrats! What exact type of battery do you have?
  8. JariT
    JariT Rookie
    Nov 25, 2011
    42
    Switzerland
    OEM charger is too weak (0.8A) to keep battery in good condition and will lead to battery failure in long term. Get the solution proposed here and your battery will last for long time. I’ve burned one 458 battery with OEM charger after 4 years and after that I changed to CTEK 5.0. I’ve used CTEK 5.0 for my 360 Modena for past 11 years and battery is still like new.
  9. GPWCR
    GPWCR Rookie
    Nov 8, 2021
    6
    Orlando, FL
    Buy a AntiGravity Battery and call it a day. I haven’t used the factory charger since I bought the car and it starts up every time with no issue even if I leave it for weeks at a time.
  10. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,431
    Tampa FL
    Is there a ctek that come with the magnetic plug for my 488?
  11. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,431
    Tampa FL
    So you all are saying the Ferrari charger i hit with my 2019 488.... the bigger black box version isn't doing as good of a job as a CTEK would do?
    AD211 and 430jm like this.
  12. 430jm
    430jm Formula Junior
    Jun 11, 2017
    448
    Atlanta
    Yep, the original sucks!
  13. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,083
    Todd
    The OEM Ferrari charger is a CTEK
