KABOOM! | FerrariChat
KABOOM!
Discussion in 'Ferrari Discussion (not model specific)' started by rob lay, Nov 20, 2003.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,252
    Southlake, TX
    Rob Lay
    time correction
  2. LRPMAN
    LRPMAN Formula Junior
    Oct 31, 2003
    383
    Aiken S.C. & FL.
    George Pavlisko
    No the engine did not blow. Has ANYBODY tried this stuff as an engine cleaner? Going to play with it on the Jaguar engine 1st and see what happens. Tried it on general clean up and it worked fine. Any thoughts?
    Take Care
    george P.
  3. richard
    richard Formula 3
    Nov 3, 2003
    1,404
    Los Angeles
    Richard Thompson III
    Judging by the way it took the crap off the floor of our garage it should probably be able to eat its way through your engine block in about 5 1/2 minutes! :D
    I would wear some damned thick gloves if you decide to scrub with that stuff!
  4. JaguarXJ6
    JaguarXJ6 F1 Veteran
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    EXTREMELY corrosive. Use it in small areas at a time. What Jaguar engine? I'm almost afraid. Is it that dirty, snap a pic for us?
    I'm a devote follower, btw. Great stuff.
    Sunny
  5. LRPMAN
    Oct 31, 2003
    383
    Aiken S.C. & FL.
    George Pavlisko
    Thank you, this is th engine
  6. scuderia47
    scuderia47 Karting
    Nov 5, 2003
    229
    Mainland
    Bill
    LRPMAN,
    Is that an XJS V 12? we had one a while back....a sensor in the fuel injection system went....we got frustrated, so my father and I ripped out the fuel injectors and put 6 double barrel Webber Carbs on it...and removed the cat. after that the car shot flames....not to mention that the engine bay would catch on fire every so often.
    the engines in those cars are sooo smooth with a nice torque curve.
  7. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #7 Spasso, Nov 23, 2003
    My personal experience for removing dirt is Simple green. Biodegradable, non-flammable, smells good too. Let it soak overnight and hose it off with warm water.
    For the corrosion on the aluminum (nonpolished) I use NAPA brand Aluminum Brightener. Nasty stuff but it dissolves corrosion down to the bare aluminum. If I remember correctly it contains Hydroflouric and Sulfuric acid. I used it on my engine with wiring and hoses removed.
  8. pete04222
    pete04222 Formula Junior
    Nov 1, 2003
    613
    Maine, USA
    Peter Cyr
    Spasso, That is Awesome!!!!!!!!!!
  9. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Suuweet Spasso. How long did it take you to get it that clean?
  10. For cleaning engines I use Meguiars APC+ Diluted 4:1, Eimann Fabrik's Hi Intenisty Cleaner, And also simple green. For the corrosion on the alumnium you need something acidic you can use a wheel cleaner of some sort.
    You can get these at:
    www.properautocare.com
    www.premiumautocare.com
  11. lionsfan54
    lionsfan54 Karting
    Nov 7, 2003
    114
    Spasso, maybe this is a dumb question, but where are the air filters?
  12. LRPMAN
    Oct 31, 2003
    383
    Aiken S.C. & FL.
    George Pavlisko
    Thanks guys, sorry it took so long to reply. Will tackel that mess another day. the DUMB ROLLS has decided to pee fuel on the ground. Not very British of it. Think it is a sticky needle on the "A" BANK but that is another story.
    To many cars and NOT ENOUGH time!
    Take Care
    George P.
  13. ollie
    ollie Karting
    Oct 7, 2001
    165
    San Juan Capistrano
    Oliver B. Cagle
    What the CART guys use. Break shoe cleaner. It works and drys fast. No engine likes water.
  14. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Starting on Friday night with the Simple green I finished on Sunday night.
    The process removed fuel and oil stains and I buffed what I could with assorted wire wheels on my drill motor. The timing covers were done with Simple Green and Mothers Mag Cream. NO acid!
    I wrote up the process in detail as a tech article on another site.
    DJ
  15. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    On the bench. Because I was still working on the engine bay, cleaning and paint, I left it off.
    The Vstacks are just sitting on the carbs for the picture. The correct order of assembly would be aircleaner base, velocity stacks (16 nuts and washers!) and lastly the aircleaner top (4 more nuts and washers).
    DJ
  16. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I have noticed on occasion in numerous threads that many people are dead set against spraying water on their engines. In the case of cars with electronic fuel injection, computers and a myriad of sensors I would be worried too.
    My car is carbureted, no electronics, no computers and only basic sending units for vitals. The plug wires were off of the car, the spark plug wells were blocked with rubber corks and the tops of the carbs were bagged and taped. The distributor caps, coils and solid state ignition modules (the obvious stuff) were sealed in duct tape and it goes on...............
    After I was done I blew everything down with compressed air and put it all back together. It fired right off. NO BIG DEAL. Nothing went Kaboom either! Just a little common sense.
    I don't suggest walking up to your engine and just letting loose with a pressure washer without THOROUGHLY sealing everything!.
    DJ
  17. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    I disagree. That's VERY British of it! Just ask my Lotus.
  18. lionsfan54
    lionsfan54 Karting
    Nov 7, 2003
    114
    Is that a 302 Ford crate motor?
  19. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    George-
    What model is your Roller?
    Believe it or not, some Rolls engines were designed to pee fuel!
  20. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    Why? A James Bond self destruct? My Lotus was designed to leak gear oil to keep the suspension lubricated.
    Ken
  21. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Err, no, it's just your run of the mill Original Equipment 3 liter V8 built by some Italian guys after a nice meal of wine and cheese and a three hour siesta.
    I wish it was as inexpensive as a 302. I'd have 2 or 3 for spares.
    DJ
  22. lionsfan54
    lionsfan54 Karting
    Nov 7, 2003
    114
    That's in your 308 (sig pic)?
  23. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    That is correct, the picture of the engine I posted in this thread is the orginal Ferrari V8 the car came with. Even the numbers match.
    DJ
  24. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Luv it but no, that's not the reason for the fuel purge.
    On the carbureted late post-war RRs, there's a fuel purge tube which exits mid-rear of the engine.
    The first time I saw it happen, I was under the car while it was being aligned. Suddenly spit, a liguid dripped out of a tube at the rear of the engine; it was petrol!
    I immediately called my RR Tech., and he told me not to worry. As I recall, he said it's supposed to do that, as it purges excess raw petrol from the intake manifold after the engine is shut down.
    Ken, your Lotus doesn't 'leak' gear oil; as with any British car, it's more commonly referred to as 'controlled seepage'!
    Also, it looks like we're neighbors, I live in Mount Prospect. Would you be interested in coming to any Ferrari and/or RR events?
    You can email me privately.
  25. Sophia
    Sophia Formula Junior
    Aug 17, 2003
    298
    Dash Point/Federal W
    Peter Barbin
    I give my car a good run, then let it cool to a warm to the touch state. Back the 308 up on some good grippy ramps. Then I jack it up further with a hyd. jack via a 4 x 6 x48" placed laterally across the rear frame tubes. Then, jack stands in...rear wheels off, wheel fairings off...time to clean.
    I use "Castrol Super Clean," works VERY well. Caution: Dilute it or it can 'bleach out' black plastic parts. I go 50/50 with water. It's bio-degradable, cuts water based dirts, and oils.... I have a hot water tap available for washing, which hastens the effect of this degreaser. Using several light applications with thorough rinsing, the effects are dramatic. Now you can read the color of your wiring! Don't leave it on raw polished aluminum very long... and never on dry metals, hose the surface down with warm water if available before applying this stuff...if not, this is where you could find a bit of corrosive action occurring.
    On the 308, I now take duct tape and cover the clutch housing vent holes, all of them, as well as the trans vent before a liberal bath. This I learned the hard way; as even though I drove the car for a half hour after the engine bath, enough water got in and literally steamed up my starter solenoid... A week later, dead starter!
