KERS and DRS ***SPOILERS*** | FerrariChat
Discussion in 'F1' started by tifosi12, Apr 10, 2011.
  1. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,449
    @ the wheel
    Andreas
    #1 tifosi12, Apr 10, 2011
    In Sepang we saw the true benefits of KERS and DRS and I have to say I'm loving it! Particularly in combination with a wide track with long straights.
    There was more passing in this race than in an entire past F1 season. Of course it also helps when some cars don't have KERS or a KERS that doesn't work.
    I was an early critic of DRS thinking it is too convoluted for the drivers, the fans and the race stewards but as it turns out, they got it all nicely organized and working. I was wrong and I have no problem admitting that given lots of passing in return.
    There were so many good scenes in Sepang. 3 cars going into the last turn, dragracing down the straight away. This looked like the glory days of NASCAR or Indy500 but it was F1, where cars do more than just ovals.
    To me it looks like the FIA finally found something that's working and making the races a lot more interesting. Add to that the degrading Pirellis and we have a pretty intense race.
    I'm looking forward to more tracks like Sepang: Silverstone, Monza, Nuerburgring, should all be good.
  2. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    As posted in the race thread, it appears to me to be working.
  3. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,461
    ESP
    Bas
    I'm loving it personally. Was very happy to see some proper F1 racing going on again.
  4. AlexO91
    AlexO91 F1 Rookie
    Sep 26, 2008
    2,909
    NW England
    Alex
    I'm not convinced.... yet. The BBC said the DRS could be tweaked slightly in the near future, if that goes well then maybe I will like it more.
  5. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    The passes came too easily imo. DRS is good but needs to be dialed down at tracks with such long straights.
  6. DF1
    DF1 Two Time F1 World Champ
    DRS is like KERS. It should be available at the driver's discretion. Not at the whim of a some race official.
  7. LightGuy
    LightGuy Four Time F1 World Champ
    44,746
    Texas
    David
    Should have been allowed on both grandstand straights.
    You pass me than I pass you back. Or verse vicey.
    And what happens in a train ?
    Are all allowed to use it except the leader ?
  8. AlexO91
    AlexO91 F1 Rookie
    Sep 26, 2008
    2,909
    NW England
    Alex
    As long as they are within a second of each other yes. I'm fairly certain I heard Martin Brundle say, "if you are within a second of the driver in front and you pass him before the activation line ie at the last corner, you can still use it down the straight."
  9. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,776
    Atlanta
    John!
    Boy you said it. Good times. When a driver can use the wing and KERS together the car really can pick up some serious time down the straight. Good stuff.
  10. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    I wrote it off as a gimmick but it seems to be working.
  11. Peloton25
    Peloton25 F1 Veteran
    Jan 24, 2004
    7,646
    California, USA
    Erik
    Quick question for clairification - do you have to be one second behind a car you are racing for position, or can it be any car on the track? Seems the latter would make more sense.
    >8^)
    ER
  12. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    I assume any car. Backmarkers can be roadblocks too.
  13. Etcetera
    Etcetera Two Time F1 World Champ
    23,757
    C6H14O5
    It's no gimmick.
    It's also a little known fact that DRS was Jos Verstappen's idea.
  14. kraftwerk
    May 12, 2007
    26,826
    England North West
    Steve
    LOL
    So little a fact that only you knew about it..
  15. classic308
    classic308 F1 Veteran
    Jan 9, 2004
    6,816
    Westchester, NY
    Paul
    Jos Verstappen is Chuck Norris' racing name, for he's the only one who could have survived the Hockenheim bbq.
  16. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    23,464
    KL, Malaysia
    MC Cool Breeze
    +1000
    They should be allowed to to anytime, anywhere.
  17. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    then there'd be no point to it.
  18. tifosi12
    Oct 3, 2002
    49,449
    @ the wheel
    Andreas
    Why?
  19. poyta
    poyta Karting
    Mar 7, 2004
    203
    Adelaide
    Peter W
    Love it in the race but I don't agree that it can be used whenever during qualifying. It's a tool designed for overtaking - seeing there's no overtaking in qualifying there should be no DRS.
    Probably explains why certain cars are so much more faster than others in qualifying but are more closer to others times during the race.
  20. poyta
    poyta Karting
    Mar 7, 2004
    203
    Adelaide
    Peter W
    Because if the guy in front and the one behind both have their DRS activated then neither will benefit for it - Kind of like that now with KERS really. Who cares if you're getting an 80- hp boost if the guy in front is also getting it.
  21. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    I have no problem with its use in qualifying. That's one of the few chances the drivers have to get used to it.
    Their lack of familiarity showed in Australia when more than one was caught out by the transition from high to low grip.
  22. tifosi12
    Oct 3, 2002
    49,449
    @ the wheel
    Andreas
    I get that and I also agree it should not be used in qualy.
    But: why can't it be used under the current rules on the entire track?
    Why only allowing it in one spot?
  23. P1-EH
    P1-EH Formula Junior
    Sep 10, 2007
    416
    Waterloo, Ont.
    Mark
    After Australia, I was neutral on DRS. Having watched its effect in Malaysia, I am now very much opposed to it. It's a complete contrivance, and makes passing on circuits like this trivial to the point of being an embarrassment to the sport.
    There is no drama in a DRS-initiated pass. The regulations put the lead car in a completely compromised position. They could have done it cheaper by requiring a lead driver to lift when trailed by a car closer than 1sec behind. It's silly.
    What we do have is a spectacular range of performance in the Pirelli tires. This alone will result in lots of great passes, driven not by contrived disadvantages, but by race strategy, and tire management.
    I hope they scrap it. Heidfeld got P3 because he had DRS (and KERS, but I'll leave that issue alone). Webber should have been able to fight back, but didn't/couldn't. I hated that pass.
    Anyhow, I think the season is shaping up to be another great one. I just hope the desire to improve the show with DRS doesn't backfire.
  24. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    +1.
  25. LightGuy
    44,746
    Texas
    David
    Understand that if the cars are relatively equal then the passed car next lap has the upper hand.
    Rinse and repeat.
    However if the car in front in the first passing lap really was slower (and previous aero limitatations restricted passing which they did) now the trailing car has a means to get around him once and for all.
    Contrived or not this is good for entertainment and when it boils down thats what racing is.
