Key Blanks for Ferrari's model years 1975 to 2005 | FerrariChat
Discussion in 'Technical Q&A' started by bisel, Aug 31, 2017.
  1. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    #1 bisel, Aug 31, 2017
    I have received several requests for plain vanilla key blanks for Ferrari’s. I have a small stock of key blanks, but my costs are such that I cannot match prices of larger sales outlets on the Internet.
    Listed below are various key blanks for Ferrari’s. I hope this helps those of you who may be looking to get a blank key to have made as a spare. Because sources, availability and prices for these key blanks can vary, perform a Google search using the key blank manufacturer and model number.
    Ferrari Model Years 1989 – 2005. Cars manufactured in this date range typically utilize a double-sided, external cut ignition key. The following model key blanks should fit these cars:
    • ILCO FT46 / X152 … brass key, plain head
    • JMA FI-6I … steel key, plain head
    • JMA FI-6I-P … steel key, rubber head
    • Silca GT6RP … brass key, rubber head
    • Silca GT6RAP … brass key, rubber head (smaller head than GT6RP)
    • Silca GT6R … same as JMA Fi-6I
    Ferrari Model Years 1975 – 1988. Cars manufactured in this date range typically utilize a single-sided, external cut key for the ignition. The following model key blanks should fit these cars:
    • Silca NE9A … brass key, plain head
    • ILCO H61VR … brass key, plain head
    I indicated above if the key is steel or brass. The only reason that matters is that some hardware stores may be reluctant to cut a steel key … but that should not be a problem with a locksmith. Also, because the manufacturer may have made a steel key in the past, does not necessarily mean that they may not change for any particular manufacturing run. The info above is merely what I believe is correct now.
    I am attaching an illustration of these keys so you can compare to your existing key. Note: the shape of the key head may vary depending on the manufacturer. The key shank should match your existing key.
    Steve
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    You science is tight!
    Thanks.
    These of course are alternates to the OEM (steel) Neimans.
  3. Bob in Makiki
    Bob in Makiki Formula Junior
    May 30, 2017
    455
    Honolulu
    Very helpful. Thanks.
  4. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    Good luck finding a Neiman key. An original, uncut Neiman key for Ferrari is likely to set you back $250 or more. Maybe much more. A reproduction Neiman key $50 to $100.
    Steve
  5. JSBMD
    JSBMD Formula Junior
    Mar 17, 2007
    450
    The OC
    Steve, I just bought a red key from you for my 355.... LOVE IT!!!!!
    Thanks,
  6. hessank
    hessank Formula 3
    1,929
    Canada, Florida
    Fred
    That's some great information especially if you're planning on keeping the car like I am.
    Thanks Steve
  7. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,685
    NJ
    Peter
    Still, at $250+, it's still cheaper than replacing the key on <insert any modern car here> :)
