key cloner for 360 | FerrariChat
key cloner for 360
Discussion in 'Technical Q&A' started by albuz3, Apr 3, 2014.
  1. albuz3
    albuz3 Rookie
    Apr 1, 2014
    8
    Tucson, AZ
    Al Mayer
    Who are the best cloner's of the key fob for a 2003, 360 and how can I contact them? I have the black fob and code but do not have the red key
  2. tazandjan
    39,159
    #2 tazandjan, Apr 3, 2014
    Al- If you have the alarm code and it works, you can order a new set of three fobs and new PIN from Ferrari and have her back to original.
    First thing to do would be to see if you can start the engine using the key and Alarm PIN alone with the directions attached. If you can, then the PIN is ok and your dealer can order a full set for you. Your old fob will likely bring at least $150 after the Alarm ECU is programmed to accept the new set and new PIN, reducing your cost.
    If you just want a clone, PM gobble and he is your man.
  3. albuz3
    albuz3 Rookie
    Apr 1, 2014
    8
    Tucson, AZ
    Al Mayer
    thanks...How do I contact Gobble?
  4. tazandjan
    39,159
