430 - Key fob batteries | FerrariChat
430 Key fob batteries
Discussion in '360/430' started by [email protected], Jun 25, 2022.
  1. tim@timmikel.com
    Mar 21, 2009
    49
    Ventura, CA
    Tim Mikel
    I replaced my key fob batteries two months ago with Tyrone brand 3V CR1220, they worked, but they have already died. Does anyone have a recommendation for a longer lasting brand? Also, in the process of changing the batteries last April, I lost the little plastic ring that houses the two batteries. Is this piece important or maybe have something to do with the short battery life I am experiencing? I appreciate any help. Thanks!
  2. BlacktopRacing
    BlacktopRacing Formula 3
    1,001
    Pittsburgh
    Dale
    Are you sure the batteries are dead? Did you test them with a voltage meter? If you don't use the key fob for a while, it loses its memory and you have to follow a procedure to reprogram it.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,960
    Isle of man- uk
    Give the contacts and battery a clean with electrical cleaner and a cotton bud
  4. LorenzoR
    LorenzoR F1 Rookie
    I just go to an Interstate battery store for mine. They can check the batteries there
  5. Qavion
    Qavion F1 World Champ
    14,273
    Ian Riddell
  6. tazandjan
    39,164
    Not sure Mark works on F430 or 612 fobs.
    Qavion likes this.
  7. Qavion
    14,273
    Ian Riddell
    Ah, ok, Terry. I assumed again :oops:
    I assumed that because Mark was incorporating 360 immo fobs into keys now (430 style), I thought that was because he had had experience with 430 fobs.
