Key fob possible issue | FerrariChat
Discussion in '348/355' started by Dennis Wright, May 1, 2022.
  1. Dennis Wright
    Dennis Wright Rookie
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    When I press the key fob once, the car beeps once, doors lock, then it beeps 4 more times (this is not how it should be)....press fob again, doors unlock, beeps twice, then car won't start, it cranks,but does not start.....any ideas? I'm about to get a new battery for the key fob
    Any suggestions? I've disconnected and reconnected the battery and it is still doing the same thing
  2. tazandjan
    39,195
    Alarm siren batteries may be shot and you might need a need a new siren. Is the LED going out?
  3. Mike Morrissey
    Mike Morrissey Formula 3
    1,143
    Denver, Colorado
    Mike Morrissey
    Four chirps upon locking indicates that a door, engine bonnet or trunk bonnet isn’t closed properly, or the switches/sensors on one or more aren’t closing the loop.
    Dennis Wright likes this.
  4. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Thank you for this reply
  5. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Thank you for the information
  6. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Key fob operating as it should
    One beep, doors lock... press fob again, two beeps and it should start... it cranks, but won’t start!
    I don’t know what else to try
  7. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Car fob key working as it should ... car ran fine yesterday, the only thing I did, was put the top down..
    Now, the fob beeps twice as it should, but, car does not start! It cranks, but won’t start...
    Any suggestions?
  8. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Alarm won’t go off now, turned power off, letting it sit for an hour... see if that fixes the car not starting issue
  9. Qavion
    Qavion F1 World Champ
    14,349
    Ian Riddell
    The roof has nothing to do with the alarm unless you’ve flattened the car’s battery. Is the crank healthy? Can you measure the battery voltage during cranking?
    You have a USA 1998 355 F1 Spider, I assume. The F1 TCU controls the starter relay, so the inputs into the F1 TCU seem ok. If I remember correctly, the Immobiliser enables the circuits in the engine Motronic ECU and the ECU sends an OK signal to the F1 TCU. The F1 TCU adds it's own logic into the mix (gearbox in N, brake pedal pressed, etc) and if ok, the starter relay is enabled.
    If the engine is cranking, it sounds like the Immobiliser is operating correctly (and at least some parts of the Motronic ECU). With the ignition on, the Motronic ECU should enable the engine sensors and arm the fuel pump relay. During cranking, the ECU enables the fuel pump relay.
    The symptoms keep changing, so I don't know if you have one problem or several. When you say it won't go off, do you mean the LED won't go out and the car won't crank or something else?
    (EDIT) Sometimes the Immobiliser thinks it's in panic mode and requires a long push of the fob button to get it out of that mode.
    Dennis Wright and Mike Morrissey like this.
  10. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Battery tender shows battery is fully charged, key fob operating as it should, car cranks fine.... will not start.... could it be the alarm not letting it start? Is there a way to reset or check this?
    Qavion likes this.
  11. Qavion
    14,349
    Ian Riddell
    This seems unlikely because the alarm is letting the car crank. No firing may be an ECU issue, a timing issue, fuel supply/pressure issue, electrical power issue....
    If you do a battery reset, then turn the ignition on (not start), do you hear the fuel pump priming for a few seconds? Note that the pump is not all that noisy, so turn off your aircon and radio before doing this. Fuel pump priming does not rely on the immobiliser (I confirmed this on my own 5.2 car).
    If no priming, check your fuel pump fuse (in the passenger footwell) with an ohmmeter. Reseat the M and N relays. There was a gentleman with an aircon issue on the 360/430 forum, recently, who spend days trying to diagnose his problem. He said he checked the fuses, but, we discovered later, he only did it visually (and missed the break in the fuse). If in doubt, swap it with another (non-essential) fuse.
  12. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    My ‘ghost’ Ferrari...
    Had it towed 50 miles to a Ferrari specialist shop called Norwoods... car arrived, unloaded it... and it started!... no issues!
    Mechanic will swap some relays and check a couple of sensors... it should be towed back to me today
    tres55 and Qavion like this.
