430 - Key Restoration 2.1 - Tricolore | FerrariChat
430 Key Restoration 2.1 - Tricolore
Discussion in '360/430' started by Tackleberry, Sep 6, 2020.
  1. Tackleberry
    Tackleberry Formula Junior
    371
    United Kingdom
    Being pleased with the results of the second attempt at restoring one of my Keys (F430 Key Restoration - #17) I thought I'd try something a little more adventurous for the other - spare -Key.
    Again using Zero Paints products (primer, base coat & lacquer). They rather conveniently do a Tricolore Set consisting of the correct shades of Green, White & Red.
    Philippine Green
    Anti-Flash Wite
    Fire Engine Red
    As before I followed the Zero Paints instructions to the letter which gives a lovely even finish, almost to the point it doesn't need polishing.
    However as before, if you're going to do a job properly..........
    I flatted the three parts back with 5000 grit and two stage polished them using my Rupes Nano, first with Meguiars M105 then finishing with M205.
    Lastly I applied some Meguiars ultimate liquid wax and buffed to finish.
    And here are the results.........................and now my #1 Key !
    And the finished pair together
    simongnz, Qavion, LorenzoR and 15 others like this.
  2. f355spider
    f355spider F1 World Champ
    18,045
    Impressive!
    cole328 and Tackleberry like this.
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Love it!
    Tackleberry likes this.
  4. S F
    S F Karting
    May 13, 2016
    167
    Texas
    Looks amazing, great work!
  5. Tackleberry
    371
    United Kingdom
    Thank you kindly gents :)
  6. cole328
    cole328 Formula Junior
    May 9, 2014
    882
    wow....! even better than the first attempt !!
  7. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,166
    Wash DC area
    Robert
    Nice work, great idea!
  8. William Chrisman
    Apr 7, 2019
    15
    William
    Pro’s pro result
  9. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    very cool.
    Now never put it in your pocket with other keys, change, money clip...:D
  10. Tackleberry
    371
    United Kingdom
    Exactly !
    Not to mention just about any kind of key ring having the sole purpose of key destruction too.
    Another idea is forming...........
  11. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    When I bought my car (a 360) the key was painted to match the color of the car. But, as expected it was a little scratched up so I did the full tilt and stripped it, primed it, and repainted it. But the new finish was no match for the destructiveness of the 360 fob attached via a key ring for the alarm and door locks--- even when not putting anything else in my pocket with the key. So I hope that "new idea" is one that will help us 360 owners too.
    Our Ferraris' are special and you have made the key to them just as special as the car. Nice job, very nice.
  12. S F
    S F Karting
    May 13, 2016
    167
    Texas
    Does the logo simply pop out or is it glued in? I have what looks to be a CS key that came with my 360 but it's pretty beat up and seeing this makes me want to refinish it.
  13. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    When I did my 360 key, the little horsey logo did pop off fairly easily.
    S F likes this.
  14. Tackleberry
    371
    United Kingdom
    Close to a solution - or I know what I want to achieve - just need to make it workable and easy to use.
    KC360 FL likes this.
  15. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    When I refinished mine, I carefully drilled a small hole from behind so that I could push a jewelers screwdriver in to push it out from behind. The logo is held in by a very small piece of double sided trim tape.
    S F likes this.
  16. Bob in Texas
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Stop! Don’t use that key. It’s a work of art and needs to be in one of those shadow box picture frames. Or wrap it in PPF, anything but your key chain where it can get chipped.
    Sent from my iPad using Tapatalk Pro
  17. Tackleberry
    371
    United Kingdom
    Don't worry Bob, that will never see a key chain ;)
    Bob in Texas likes this.
  18. Tackleberry
    371
    United Kingdom
    Solution found - KGC & Bob ;)
    Pretty much every keyring (fob) you buy these days has one thing in common - the metal ring - which it's seemingly single purpose in life is to completely trash our lovely keys.
    Way back when keys were nothing more than a piece of metal, with maybe a black plastic part, the metal keyring were just fine. However these days, and most definitely in the last 15 years, our keys have become more decorative but the good old key ring has remained the same, despite the fact most are leather the ring itself ends up causing unsightly damage.
    It is worth noting now that what follows next is of no use if your keyring is all metal, this is only really applicable to leather versions.
    After a bit of head scratching this is what I came up with.
    First question is, does the ring need to be metal ?
    Well actually no, it does not. I imagine most of use only keep the one key - the important one - on said keyring, and you're certainly not going to rappel down a zip line hanging off your key (unless you're possessed by madness !).
    So what to use that is both sufficiently strong enough to secure the key to the keyring, but compliment enough so as not damage the key ?
    The solution - as you will see in the attached images - was to use the following items:
    Rubber (nitrile)or Silicone O-Rings
    Paracord
    Bayonet End Clasp
    The End Clasp needs to be sufficiently large enough in outside diameter so as not to flop around in the end of the leather fob, yet able to pas through the hole in the key.
    The ideal size was to take 4mm cord, which meant the outside diameter was 5mm, and thus able to pass through the hole in the key.
    The rubber cord - in this case a suitably sized 4mm cross section O-ring - was then bonded in the End Clasps.
    Hey presto ! Version 1 successfully made.
    However a Black Rubber O-Ring is a little bland, so I tried something else.
    I had some 4mm Paracord, and one thing you can do with this stuff is pull the inside cord out so you are left with sheath.
    I then used a 3mm cross section O-Ring and passed inside the Paracord outer sheath.
    Then as with the Version 1 I bonded the End Clasps on to the ends.
    Much better, and a little more decorative.
    And of course Paracord comes in many different colours !
    So what about strength and integrity ?
    I've tugged just about as hard as you want to on the ends and they have not come adrift.
    And to be honest how much force do you realistically need to apply to your keyring. It's as secure as it needs be and does not come apart on it's own.
    And most importantly - no damage to the Key !
    Anyway, the following pics are the fruits of my labour.
  19. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    that looks amazing, you'd make a ton of money offering this as a service!
  20. Tackleberry
    371
    United Kingdom
    Thank you :)
    Just gauging reaction and feedback before taking it further.......
  21. Bob in Texas
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Genius!
  22. Tackleberry
    371
    United Kingdom
    Thank you kindly Bob :)
  23. bhobson
    bhobson Rookie
    Feb 28, 2022
    48
    Memphis TN
    Blake Hobson
    What primer/paint/top coat did you use on your silver 360 key? I have a nice one and a beat up one. I'd like to refinish the beat up one, but I'd like them to match. Comments appreciated.
