I have a Ferrari Mondial QV 1988 that I use only in the spring and summer. I have just got it ready for use, but noticed it had a flat battery. I opened the car door with the door key and left the keys on the seat, but when the door closed the central locking automaticly locked itself shutting my only door key in the car !!!! I assume this happened because the car had a flat battery. Anyway does anyone know of a way of getting the keys out without smashing any windows? Have tried wire through the door seal, but the knob does not want to pull up - any other ideas?
I don't know if a slim jim will work, the door lock uses two rods that move in a linear fashion vs up/down. at least that's the way it is on my Mondi.
Get another set of keys made once you get inside. Never understood that...I always have at least two and sometime as many as four sets of keys for every car I have owned.
i'm not familiar with the mondial locking mechanism, but try asking a locksmith, if it is possible to pick the lock first. that way you can avoid using a slim jim. i've seen a locksmith do it on other non-ferrari cars using lock picks and applying very little pressure.
Since the floor tub is fiberglass, cut a hole in it just so your arm can get thru, and reach up and get your keys off the seat, or use a coat hanger thru the hole just cut to retrieve keys. then seal it back up again with another piece of fiberglass or plastic - just a thought!!
Thats quite a thought. Why not call a Locksmith and get the job done. Last time I locked my keys in the car it cost me a whopping 25.00 and took about ten minutes for the lock guy to show up.
Impressioning: http://en.wikipedia.org/wiki/Lock_picking#Key_impressioning And you wind up with another key.
having had my door apart many times, unless the locksmiths slim jim is special it won't work. the mondial has two rods that are in a north/south to the tumbler, when locking or unlocking you are actuating the lock in the door handle, this in turn is rotated in that same manner as the tumbler, so the rods move from front to back and vise versa. the door motor in the door is actually a switch to signal the passenger door motor to unlock.
You No Cal guys tip.[/QUOTE] Yup! Gregs tip is buy floor mats make your car perform better and gain value.
I was wondering that, I've also noted the door can not be locked while it is open either, you risk breaking parts. so with the first post here on how to jimmy a ferrari open it does seem suspicious.
I tipped a locksmith the other day (Renters abandoned house but left it locked up tight.) I tipped him because he gave me a couple of lockpicking tools and taught me how to use them so I'd never have to call him again.
Or its a really bad "hood" and he never wants to come back again to pick a lock? I am really surprised a Ferrari would auto lock when you shut the door. on my old 308 I cannot push my lock button down with the door open. They built a safety feature into the mechanism to prevent you locking yourself out. After trying to find a locksmith who would even have key blanks, much less be able to make a key, I decided to make 5 sets of keys and I now have spares.
Check your state laws. In some states (such as VA), owning lock picks is considered prima facie evidence of intent to burgarlize, so just owing lock picks is illegal. Sometimes (as Dickens observed) the law *is* an ass.
