keys4classics quality | FerrariChat
Discussion in '308/328' started by jonesdds, May 21, 2008.
  1. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    I purchased a set of three door and ignition keys from them but I'm always a little nervous turning them, especially in the ignition as they seem more fragile than the stock keys. I decided to put my original keys away to save them and not risk losing them and that's one reason I got so many made. Having read threads where keys broke in the ignition, I'm concerned it might happen one day. I notice on there website the explanation of brass versus steel and I'm pretty sure they are steel while the originals are brass. The write up there seems to indicate the steel is stronger, but I'm not convinced.
    I know many others have used them, should I be concerned and which keys are the strongest?
    Jeff
  2. Tony K
    Tony K Formula 3
    Jun 7, 2006
    1,779
    Tony K.
    Steel is stronger than brass. If your keys are brass, you will see the yellow brass color where they were cut; if they are steel, they will be the same color all the way through.
    If I were concerned, I would sacrifice one of the keys in experimentation to see how strong they are. Worth the $9 or whatever KforC charges.
    What brand are the keys? I've never had a bad experience with Silca or Ilco copies; they have always been of standard quality.
    - T
  3. thumpnyc
    thumpnyc Rookie
    May 19, 2007
    48
    Carmel, IN
    I have been using my keys from keysforclassics for ~6 months with no problems.
  4. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    they are fine, have 3 keys from them no problems over 3 years
  5. branko
    branko F1 Rookie Owner
    Mar 17, 2003
    3,710
    Birmingham, Alabama
    Branko Medenica
    I wouldn't worry about the keys.........now the ignition tumblers that is another matter. Don't ask me how I know.
  6. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    I have a set from them, been using it for about 3 or 4 years. Work great, no problems. I don't have the keys with me so I cannot tell you if they are brass or steel, but I believe they are steel.
    Alberto
  7. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,767
    26.806311,-81.755805
    Dave M.
    Used a set of his keys going on 5 years in the Dino without incident. New owner is, I suspect, still using them now.
    Original Dino keys are steel, replacements are not. Most key cutters don't want to work with steel keys in their machine, or so I am told.
    DM
  8. Bullfighter
    Bullfighter Two Time F1 World Champ Lifetime Rossa Owner
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    I have a set from Keys4Classics. They are brass -- you can tell by the cut edge. They work great, although I've had them <1 year.
    My ignition switch turns easily, so I doubt it would break off.
  9. dm_n_stuff
    Dec 10, 2003
    43,767
    Dave M.
    My guess is the softer brass keys may actually cause less wear and tear within the ingnition mechanism. Softer metal=less wear.
