Kickdown switch | FerrariChat
Kickdown switch
Discussion in '365 GT4 2+2/400/412' started by 180 Out, Aug 9, 2013.
  1. 180 Out
    180 Out Formula 3
    Jan 4, 2012
    1,286
    San Leandro, CA
    Bill Henley
    #1 180 Out, Aug 9, 2013
    In my '83 400i, the microswitch that energizes the kickdown solenoid in the TH400 recently stopped working. I bought a lot of four used microswitches on eBay for $10 plus $13 shipping. The part number is Honeywell BZ-2RW82255-A2-S. Last night I replaced my broken switch with one of the Honeywells and it works perfectly.
    I could not find a direct replacement for the OE unit, but web searches suggested this Honeywell would work. There are two requirements: that the mounting holes be 1" apart, and that the switch use a spring-loaded lever with a roller on the end, like the OE unit. I found no other alternatives with both features. I'm attaching a picture of the Honeywell. These seem to be readily available on eBay and elsewhere, for around $25. They appear to be very solid and high quality.
    Edit: The part number that Ricambi America gives for this switch is 106603. Link: Ferrari 400i Parts : Table 12 - THROTTLE CONTROLS (FOR LHD). The switch is number 47 in the attached drawing. It's described as "Micronterruttore per Kick - down Vale per 400 Aut." Ricambi's price quote is the always ominous "Call."
  2. Steve Magnusson
    26,775
    Bill -- Please add a post with the F PN so this comes up when searched by F PN -- TIA.
  3. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Which of the three terminals do the red and white wires connect to? Thank you. Jq.
  4. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I would expect nothing other from Honeywell.
  5. 180 Out
    180 Out Formula 3
    Jan 4, 2012
    1,286
    San Leandro, CA
    Bill Henley
    The three terminals on the switch are labeled "Common" for the hot lead, and iirc "Normally Open" and "Normally Closed" for the other two. Our cars use the one labeled "Normally Open." I used a test light to identify the hot lead on my car, and did not go by color.
