killing the red led light on 355 | FerrariChat
Discussion in '348/355' started by hummerboy24, Oct 31, 2013.
  1. hummerboy24
    hummerboy24 Karting
    Sep 5, 2012
    68
    Winston-salem
    Tony
    Can someone tell me if it does happen to me, where to access the alarm so I can change out the battery in the 355? if I do change it out will I have to reprogram anything or should it just stop the led that stays on while the car is running? thanks
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    The Alarm ECU is on the driver side of the trunk, under the trunk liner.
  3. hummerboy24
    hummerboy24 Karting
    Sep 5, 2012
    68
    Winston-salem
    Tony
    ok thanks...Would I have to reprogram anything if I changed the battery? what size battery is it? Thanks
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Look for any number of previous threads - the alarm sounder 177148 is a three hundred buck module - the diy chop & rewire is possible - there's been a photo thread in the past - some folk get success with a corvette module - no reprogramming should be needed unless you isolate the main 12v battery in which case the radio will need it
  5. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    Can't the poster turn the power supply off under the hood passengers side under the 10x 10 inch cover?
  6. hummerboy24
    hummerboy24 Karting
    Sep 5, 2012
    68
    Winston-salem
    Tony
    I was going to cut the battery switch off before anything just wanted to make sure I did not have reprogram the key fob
