Kinectic powere Refrigerator | FerrariChat
Discussion in 'Other Off Topic Forum' started by 3604u, Sep 4, 2011.
  1. 3604u
    3604u F1 Veteran BANNED Silver Subscribed
    Sep 27, 2004
    6,298
    london/singapore/JKT
    D
    Hi,
    Anyone knows if the movement of a truck can use its kinetic energy to power up a fridge instead of using oil or electricity.Maybe a back up generator would be good.
    I am not an engineer, I am just asking for any of your opinions.
    Hope this idea is not too silly.
    Many thanks
  2. DGS
    DGS Seven Time F1 World Champ Rossa Subscribed
    May 27, 2003
    71,962
    MidTN
    DGS
    What kind of movement are you referring to?
    The forward movement of the truck is powered by the truck engine.
    Adding any cooling load to that would simply put a larger stress on the engine, using more fuel.
    A vehicle air conditioner works that way: using the engine to drive the compressor for the compression-evaporation air chiller, which is the same process used for refrigeration.
    Driving the compressor off the wheels instead of a belt is just a different way of linking the compressor to the engine output, wiht the added complexity of the large range of RPM on the wheel axis, versus the engine crankshaft.
    By contrast, if you're referring to trying to tap the energy absorbed by the air ride suspension, I'm not sure there's any way to get anything from that except low grade heat in the suspension components, which would be hard to concentrate into a form that could drive refrigeration.
    Heat is a low "grade" energy, compared to electricity or mechanical motion. You need a heat gradient for a Carnot cycle.
    I once thought about trying to collect the reentry heat from a shuttle's nose cap and leading edges, in order to provide propulsion for a powered landing approach.
    But the hardware to accomplish that would weigh more than a simple conventional turbofan and an hour's worth of Jet-A.
  3. treatme
    treatme Rookie
    Sep 6, 2011
    1
    nice idea man
  4. Etcetera
    Etcetera Two Time F1 World Champ Silver Subscribed
    Dec 7, 2003
    23,992
    C6H14O5
    Put oval tires on the truck and I'm sure you could power a small neighborhood.
