Kingsborne spark plug extenders? | FerrariChat
Discussion in 'Mondial' started by Bloody Knuckle, Feb 19, 2013.
  1. Bloody Knuckle
    Bloody Knuckle Rookie
    Feb 4, 2013
    16
    S.F. Bay Area
    Hello,
    I need spark plug extenders for my '86 Mondial. Shopping around I found that Kingsborne has these at a very good price. Does anyone have any experience with these extenders? Are they a good quality product?
    Thanks in advance.
  2. My365
    My365 Karting
    May 4, 2009
    191
    Baltimore, MD
    Bought a set of them for my 86 last year. They fit much more securely than what was in there before. They seem to be better designed than the originals too. There is more of a gap between the metal connectors inside and the wall of the extenders. I would assume this would lessen the chance of arcing and burn through. I would recommend them to anyone.
  3. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    May I ask your source, please?
    Thanks!
  4. David Lind
    Nov 19, 2008
    2,248
    David Lind
    Never mind; I found them easily!
    Any more feedback on this non-OEM part?
  5. Bloody Knuckle
    Feb 4, 2013
    16
    S.F. Bay Area
    I ended up eliminating the extenders. Another member, "jlc308", sent me these photos and part numbers of his set up. I copied it. The parts are also from Kingsborne.Good luck.
    Jerry
    View attachment Wires1.pdf.PDF
  6. David Lind
    Nov 19, 2008
    2,248
    David Lind
    I read in the 308 section that some of these extenders have or need resistors. Does the Mondial 3.2 need resistors in the extenders?
  7. Bloody Knuckle
    Feb 4, 2013
    16
    S.F. Bay Area
    I think the 3.2 uses 107mm, 0 ohm non-resistor extenders. The earlier models use 100mm, 2 or 4 ohm extenders. I'm not 100% sure on this. Maybe some one with more knowledge will chime in. Hope this helps.
