knock offs for 308? | FerrariChat
knock offs for 308?
Discussion in 'Technical Q&A' started by st@ven, Jul 23, 2009.
  1. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    Anybody know were to find knock-offs or single lock modifications for a 308?
  2. DGS
    DGS Seven Time F1 World Champ
    73,069
    MidTN
    DGS
    Just off the top of my head:
    How interchangeable would 308 and 512BB hubs be?
  3. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    No but there is a way. There was a very rare dealer option back in '76 - '77ish to have wire wheels on a 308.. Some 246's came with knock offs installed by the dealer as well.. I know a guy who bought Yngwie Malmsteen's 308 from him.. Yngwie found an adapter that allowed him to install Borranis on his 308.. Not sure where to get those but it is possible to put knockoffs on a 308... I am sure someone on here knows.. Good luck.
  4. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,425
    E ' ' '/ F
    Enzo Gorlomi
    #4 GrigioGuy, Jul 23, 2009
  5. RBV24961
    RBV24961 Formula Junior
    May 23, 2006
    290
    Rye, New York
    Peter Sweeney of Forza Motorsports had a set of Borranis with adapters for a 308 about two years ago. Not sure if he still has them but i'm sure he would know if anyone does.
    860-350-1140
    http://www.forzamotorsports.com/
  6. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    I have seen boxer wheels on a GT4. Im am not positive but I think the bolt patterns for the spline match the 5 lug 308 wheel.
    Rob
  7. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    Thanks guys but maybe i miswrote.
    I'm not really looking for knock off but for wheels with a centre nut (like a boxer or older TR, can't find it here anywere but maybe i use the wrong search term. )
    I like to find leades to a complete or parts of a set-up ( wheels, spline, adapartor, whatever t takes) to provide my 308 with these cetre nut wheels.
  8. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Knock-off's, centre-lock, same thing.
    I don't know what the hubs/adaptors of a 512 would do to the track, but suspect they might fit.
    If not, buy a set of adaptors/splines drilled to fit the car. I am sure that MWS in the UK, or Dayton in the US could help with this.
    The centre nut can then be had without ears, or with 2 or 3 ears. I'd love to have 3-eared spinners on my car, but it'd be a pretty expensive conversion, as you need the hubs/adaptors, wheels and spinners.
    If it is wirewheels you are after specifically, you might also opt to buy a set of bolt-on wirewheels with Volvo PCD, which will be somewhat more economical.
  9. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    thanks Jack,
    no i'm not after wirewheels but the question is fed by my plans to make the 308 into a circuitracer. These central lock wheels seems to me kind of the ultimate racy wheel option
  10. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Have a set of new in boxes Speedline Center Lock 18" wheels made for the 348LM campaigned by Michelotto. My understanding is the hub/nut/pin is similar to, or the same as, the F-40. The wheels are easy, the hubs could be the sticking point!
  11. jsa330
    jsa330 F1 World Champ
    10,058
    75225
    Scott
    Borranis on a 308? Doesn't seem quite right.
    I do miss the knockoffs. Sweptback 3-eared ones would look great with the standard wheels on my car.
    Off to Pep Boys!
  12. Argento839
    Oct 21, 2005
    9,103
    #12 Argento839, Aug 3, 2009
    They look good on this car..
  13. BigTex
    79,406
    Houston, Texas
    Bubba
    Those center hex after market spoke mags are a center cap, over the standard bolt pattern...ie. not real.
    Not saying some of the Rally Cars didn 't have them, like the F40 eventually did.....
  14. BigTex
    79,406
    Houston, Texas
    Bubba
    There's known examples of Borrani shod GTBs but I don't think that's what he's asking......
  15. jsa330
    10,058
    75225
    Scott
    Good looking car. I don't know about the Borranis...maybe I'm just set in my ways.
    To me, ideal 308 wheels would be Boxer-type, with real knockoffs.
  16. DGS
    73,069
    MidTN
    DGS
    #16 DGS, Aug 3, 2009
    For a racer, I'd think you'd want to consider swapping out the hubs, rather than bolting a spline onto the five bolt pattern.
    I've heard the odd report of 25 year old hubs having trouble on the track with modern (sticky) racing tires.
    edit: You might add new stub axles to the list, too: http://www.ferrarichat.com/forum/showthread.php?t=252591
  17. Randy Forbes
    Randy Forbes Formula Junior
    Jul 14, 2006
    741
    Sarasota, FL
    Sports Cars Plus,LLC
    Not to mention the unsprung weight you'd be adding; weight that will affect handling and acceleration.
