Koni Rebuild (82 series) | FerrariChat
Discussion in 'Technical Q&A' started by rkljr, Jan 26, 2012.
  1. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Winter is quickly passing and my plan is to rebuild the front shocks on my 308. I have a couple questions and am hoping that others have rebuilt them before. I have searched but did not find any detail on the rebuild.
    First - Tools
    What tools are needed to rebuild the shocks? Some type of wrench is required to take them apart but what exactly is it.
    Second - Parts
    In the event I need to replace any parts, what is the best source?
    Any tips on the procedure are greatly appreciated.
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Somewhere on this site using search you will find a step by step of doing the R&R on the Konis. I do know that the discussion went into spring compressors and what not to use if you want to live through it. So, you will need one of those. I also believe that the WSMs for the 308s do go into detail as well. Also, there are other web pages that go thru the step by step if you do a google search. Good luck. Also check for the BRADAN 308 GT4 restoration thread. They are doing it with pictures:
    http://ferrarichat.com/forum/showthread.php?t=336741
    towards the end somewhere.
  3. rkljr
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Thanks, I did do a search but did not find what I was looking for but I did not have much time. I will search again on the weekend.
    As luck would have it, my spring compressors do not work with these springs so I do need another set.
  4. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    Please post up here if you find it. I am intersted as well.
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #5 Crowndog, Jan 27, 2012
  6. rkljr
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Thanks, very helpful.
    I hope to get started this weekend.
