Koolmat | FerrariChat
Koolmat
Discussion in 'Technical Q&A' started by NYCFERRARIS, Nov 17, 2006.
  1. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    Was thinking of this to insulate the trunk and cockpit of my QV www.koolmat.com I know there is alot of other options but wondering what you guys thought
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Looks like it will work well!
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    That's a slick idea.
  4. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    I have used Koolmat to insulate a couple of old Jaguars that had major heat problems. It works remarkably well. It's not cheap, but works very well. Just a couple of issues. While it is relatively easy to cut to the right size, you have to use different glues to tack it down and attach carpeting to it. When I did it, I used 3M spray glue to tack down the fiberglass side, but you need silicone glue to attach anything to the smooth surface. Also, this stuff weighs alot. It's not a huge issue if you are using small amounts of it, but if you are doing the whole cockpit area of a car, it does as weight, if that's an issue. In the old Jaguars, putting insulation between the passengers and the engine/exhaust system was well worth the time, money, effort and extra weight.
  5. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,858
    26.806311,-81.755805
    Dave M.
    The stuff can be die cut.
    That means, with a proper digitized template, I can pre-cut pieces to fit exactly where I want, and then repeat the process for others.
    I'm going to look into this a little more, but I think with a little work, you could lay out the interior of your car and then simply cad/cut the pieces for application. Looks like there's a jag guy out there doing this now.
    Reduce waste, make a perfect fit.
    Hmmm......
  6. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Utah
    I have some of that on my firewall. Works pretty well against transferring heat into the car. My headers have been coated as well and combined with the koolnat translates into less radiant heat.
    If your going to to the inside of the car, i would suggest www.dynamat.com
    for your insulation needs. Much less expensive as well.
    Paul
