News
Kudo's to Groits
Discussion in '348/355' started by mj_duell, May 8, 2009.
  1. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #1 mj_duell, May 8, 2009
    I was bored a few days ago and decided to clean my dirty and dusty engine bay. I have read many posts here about how to do it without spraying the engine, but I decided to try it anyway ;). First I used aluminum foil to tightly cover every electrical connection I could find, then I used tied doubled up plastic grocery bags to cover the ignition parts and other larger items. The covering process was done carefully and took almost an hour to do. This was smart because I decided to use the dreaded pressure washer for the job. I sprayed the entire engine down with Griots engine cleaner and let it sit. The engine was warm, not hot. I had started it up and let it idle before covering the connectors so it had about an hour to reach what I think was a good temperature. I used the pressure washer very, very carefully and kept a full size terry cloth towel with me in case I sprayed something I didn't want to get wet. I was amazed with the cleaning job when I was done and must give Griots a solid plug for a good product. I had purchased the Engine Detailing Kit so I proceeded to spray the engine parts with the dressing, again very carefully. Some parts I simply wiped off because I didn't want them to be too shiny, others I left fully covered. I am very happy with the results. She won't win any show trophies, but the engine is 10 times better looking than it was. I started the car up three times in the last two days and have not had an issue.
  3. J. Salmon
    J. Salmon F1 Rookie
    Silver Subscribed Owner
    Aug 27, 2005
    4,310
    VA
    I think it is Griot's...
    But it looks great either way!
  4. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Dang! Your right. Brain fart. ;)
  5. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,760
    Hamilton, NewZealand
    James
    Looks great. Excellent work.
    Nothing quite like knowing its clean. ;)
  6. Scaledetails
    Scaledetails F1 Rookie
    Rossa Subscribed Owner
    Nov 19, 2003
    3,975
    Las Vegas
    Stephane
    stunning, great work.
  8. stuckinkuwait
    stuckinkuwait Formula Junior
    Jul 25, 2004
    630
    Northern New Jersey
    Lenny S
    nice work. Did you refoil the front of the engine cover?
  9. Monteman
    Monteman Formula 3
    2,246
    Santa Barbara, CA
    Monte
    The only thing I would caution you on is if you used the "Engine Shine" product Griot's sells. It's in the aerosol spray can. I used it on my NSX and had some real problems. It looks great for about 3 months and then starts to haze. If you try to clean it it just gets worse. When I tried to pressure wash it, it just got even worse. I simply couldn't get it off. The only thing you can do it use more Engine Shine and then it looks great again but you just can't get the stuff off once it's on. It's kind of like being a crack baby except your addiction is Griot's Engine Shine.
    Don't get me wrong, I love Griot's products but learned my lesson with that particular stuff. What I use now is their Undercarriage Spray on the engine. It is thicker than most sprays. You spray down the engine then wipe off the excess. It looks great and lasts for quite a while. The important thing is that you can get it off again when you clean the engine.
  10. gamby
    gamby Karting
    Aug 17, 2006
    229
    Honestly, Simple Green and a hose nozzle works wonders on a dirty engine bay. Armor All and towels for the rest of it. Zymol protectant looks killer on hoses, too.
  11. Night life
    Night life F1 Veteran
    6,651
    The city that rhymes with fun in Canada
    Roberto Giannini
    +1 I also use on all my black hoses in the engine tire foam spray, just spray on and leave it makes the engine bay look awesome.
  13. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Yes, Did that last March. I used DEI Aluminum Heat Shield. It's got a diamond pattern and it's faily thick and good to 1700 degrees.
    --Mike
  14. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    I have never tried Zymol protectant but I think I will get a bottle.
    --Mike
  15. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Really? Man I hope not. I'll see what happens, maybe I will try new stuff in a few months. If all else fails I guess I can become a crack baby ;).
    --Mike
  16. gamby
    gamby Karting
    Aug 17, 2006
    229
    It dries to a half-gloss finish that looks great. Looks nice on tires, but washes off quite a bit after a rainstorm.
  17. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,324
    New Jersey
    it looks awesome ............ great job!!!!!
  18. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,213
    Palos Verdes
    Vince V
    Sign on side of freeway........Will work for Engine Shine.......
    Man, I'm sick, real sick, ya know? If I could jess git some shine, ya know? Let me see the doctor! ;)
  19. sandersja
    sandersja Formula Junior
    Jan 16, 2003
    367
    Portland OR
    John Sanders
    I am glad to hear you had success with Griots engine shine. I did not. I found that it was too harsh and dulled all of the painted surfaces, and it look like it started to corrode aluminum parts. I never even finished the bottle before throwing it out.
  20. Cavallino Aficionado
    Oct 3, 2006
    1,992
    Lk. Tapps/Buckley WA
    Brian
    That stuff is great, I even use it on the rubber webbing on our patio furniture every spring.
  21. Cavallino Aficionado
    Oct 3, 2006
    1,992
    Brian
    Mike, your results look great. I'm a huge fan of ALL griot's products. I also live near thier facility here in WA state so I can go down and bs with Richard himself. I use nearly all thier car care products and my next purchase will be garage floor epoxy.
