L Type Wiper Arm and Blade Length | FerrariChat
Discussion in '206/246' started by sranderson, Oct 10, 2019.
  1. sranderson
    sranderson Formula Junior
    Nov 15, 2003
    286
    SRA
    Hello All,
    Have been absent for a while on this site, but now trying to work out a few things on my L. I have the clapper style wipers but I cant seem to get them timed properly and they collide. There is no noticeable slop in the cable or wheel boxes. I'm thinking that when I restored the car several years ago I was possibly sent the wrong arms and wipers.
    Can someone with an L please measure their arm and blade lengths?
    Thanks,
    Steve Anderson
  2. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Steve,
    They should both be 14" (355mm) blades, different countries had different blade requirements and some E-series were longer but the 14" should clear each other on a 206/L-series.
    15" will almost certainly bind.
    Andrew
  3. rosso dino
    rosso dino Karting
    Mar 5, 2009
    195
    Hi Steve,
    my blades are 400 mm. I tried to make some pics, but neither the lights in the garage are very well, nor the camera of my mobile. Hope this helps nevertheless!?
    Best
    Götz
  4. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    #4 4CamGT, Oct 12, 2019
    The adjustment of the timing is trial and error. The left side wiper movement is direct from the motor. The right side is from the cable. 1) Disconnect the cable and get the left side wiper to go through it’s correct motions (keep adjusting the arm on the spline and use plenty of water on the glass). 2) Once it goes through its motions and parks correctly, pre load the right side wiper with the cable and manually rotate the cable to have it go through it’s motions. When it’s in the parked position and ready to go up again (making sure the left wiper is also ready to move upwards), reconnect the cable. Keep doing this until the timing is correct. I found having someone help by spraying water on the glass and you inside working the switch on and off is a big help. This is the way I did mine. Maybe there are other techniques? My wiper motor is really weak though.
  5. sranderson
    Nov 15, 2003
    286
    SRA
    Thank you all for the help. As it turns out the blades on the car are incorrect and I have ordered the correct ones. 4CamGT, thanks for instructions on timing.
    dgt likes this.
  6. swift53
    swift53 F1 Veteran
    8,281
    E.S.
    Alberto
    Where are you sourcing the blades?
    Thank you.
    Regards, Alberto
