LaFerrari replacement: v12, no hybrid, less power than SF90stradale? | Page 221 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Ale55andr0, Dec 24, 2019.
  1. Challenge64
    Challenge64 F1 Veteran
    6,367
    Ron
  2. arhimede
    arhimede Formula Junior
    Aug 16, 2007
    769
    FERRARI F80 - TECHNICAL SPECIFICATIONS
    • INTERNAL COMBUSTION ENGINE (ICE)
      • Type: V6 - 120° - dry sump
      • Total displacement: 2992 cc
      • Bore and stroke: 88 mm × 82 mm
      • Maximum power: 900 cv @ 8750 rpm
      • Maximum torque: 850 Nm @ 5550 rpm
      • Maximum engine speed: 9000 rpm (dynamic limiter at 9200 rpm)
      • Compression ratio: 9.5:1
      • Specific power output: 300 cv/l
    • HYBRID POWERTRAIN
      • Type: Concentrated winding stator, Litz wire and stator and rotor in a Halbach array configuration
    • REAR ELECTRIC MOTOR (MGU-K)
      • Operating voltage: 650 - 860 V
      • Peak power
        • Regenerative braking: 70 kW (95 cv)
        • ICE assist: 60 kW (81 cv)
      • Peak torque: 45 Nm
      • Maximum engine speed: 30,000 rpm
      • Weight: 8.8 kg
    • FRONT AXLE ELECTRIC MOTOR
      • Peak power: 105 kW (142 cv) for each of the two electric motors
      • Peak torque: 121 Nm
      • Weight: 12.9 kg
    • HIGH-VOLTAGE BATTERY
      • Maximum voltage: 860 V
      • Maximum power (charge/discharge): 242 kW
      • Energy: 2.28 kWh
      • Maximum current: 350 A
      • Power density: 6.16 kW/kg
      • Weight: 39.3 kg
    • WEIGHTS AND DIMENSIONS
      • Length: 4840 mm
      • Width: 2060 mm
      • Height (in kerb weight conditions): 1138 mm
      • Wheelbase: 2665 mm
      • Front track: 1701 mm
      • Rear track: 1660 mm
      • Dry weight: 1525 kg
      • Dry weight/power ratio: 1.27 kg/cv
      • Weight distribution: 42.2% front / 57.8% rear
      • Fuel tank capacity: 63.5 litres
      • Luggage compartment capacity: 35 litres
    • TYRES AND WHEELS
      • Front: 285/30 R20
      • Rear: 345/30 R21
    • BRAKES
      • Front: 408 x 220 x 38 mm (6 pistons per calliper)
      • Rear: 390 x 263 x 32 mm (4 pistons per calliper)
    • TRANSMISSION AND GEARBOX
      • 8-speed dual-clutch F1 DCT
    • ELECTRONIC CONTROLS
      • SSC 8.0: TC, eDiff, SCM, PCV 3.0, FDE 2.0, EPS, ABS-Evo in all Manettino modes, 6D sensor
      • performance ABS/ABD
    • PERFORMANCE
      • Top speed: 350 km/h
      • 0-100 km/h: 2.15 s
      • 0-200 km/h: 5.75 s
      • 100-0 km/h: 28 m
      • 200-0 km/h: 98 m
    JackCongo likes this.
  3. I think it looks good.
    I am sure when the F40 was introduced, if there message boards back then, people would be puking all over themselves as well.
  4. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,656
    0-300 km/h?
  5. MisterMaranello
    MisterMaranello F1 Rookie
    Apr 5, 2011
    3,335
    Europe
    The price on this car is really something.
    Ca €2.950.000 net
    Over 4.5 times an SF90 XX
    Over 12 times a 296 GTB (shared engine block)
    LaF was roughly €1 million net
    Roughly 4.5 times an F12 (shared engine block)
    Just under 5 times 458/488.
    Ferrari are absolutely milking it with F80, car will probably gross them close to, if not above, €1B in gross profit. Before XX and Spider.
    ingegnere and gt_lusso like this.
  6. Blackbird4life
    Blackbird4life Formula 3
    Jul 8, 2005
    2,168
    I’m happy :D
  7. arhimede
    Aug 16, 2007
    769
    296 gtb just did a 6:58 on Nordschleife
    296 its 5,7 sec slower on Fiorano then F80, a track of 3km lenght.
    Nordschleife has 22km. So over 7 time the lenght of Fiorano. F80 may be a sub 6:30 car.
    Dirundero likes this.
  8. _Alex
    _Alex Formula Junior
    Dec 24, 2017
    303
    Sorry if this is a repeat (there are too many messages for me to catch up on) but 799 F80s and 599 SP3s. Kinda makes the SP3 more special? Though I expect there will be an F80 Aperta in 2 years with less numbers which might be a closer match to the SP3 since they are both open tops.
    imahorse likes this.
  9. therryzsx
    therryzsx Formula 3
    Dec 2, 2011
    1,358
    I wonder what will be resale price of F80...
  10. inox
    inox Formula Junior
    Oct 11, 2017
    627
    F80 is definitely a wow car.
    Interestingly, the wheelbase is 1.5 cm shorter than in W1 but overall length is 20.5 cm longer!
    Wheelbase / Length
    F80: 2665 mm / 4840 mm
    W1: 2680 mm / 4635 mm
    W1 is 1.2 cm wider, but F80 is 4.4 cm lower.
    Width / Height
    F80: 2060 mm / 1138 mm
    W1: 2074 mm / 1182 mm
    Ferrari will be much more imposing with those dimensions.
    Blackbird4life likes this.
  11. AJ
    AJ Formula 3
    Jun 23, 2008
    1,856
    Aaron
    Not to mention the F50 and Enzo designs which were both widely condemned when they were introduced. The F80 is no different and a lot of the people that hate it today will love it when they see it in person.
  12. Luka56
    Luka56 Rookie
    May 6, 2024
    19
    Luka
    I did a very poor attempt on my phone to scribble away the black trim so i could get just an estimate on how this car would look like with no black trim across the front and this is what came out
  13. Enzo Belair
    Enzo Belair Formula 3
    1,649
    Texas
    Scott
    My dealer did not have pricing, where did you get the number?
  14. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,731
    So we have to love him because Ferrari is always right and only does extraordinary things, and we have no choice but to love him, otherwise we are a stupid person... Am I right ?
    babgh, evanmcm and Johnny_Bravo like this.
  15. Johnny_Bravo
    Johnny_Bravo Formula Junior
    Dec 7, 2012
    544
    Are you blind or something ?!?
    It's ****in' HIDEOUS, especially that UGLY black stripe.
    This car is a monumental failure: it has less HP than the new McLaren, a **** V6 engine and it looks HIDEOUS.
    Ferrari's management should be executed.
  16. Johnny_Bravo
    Dec 7, 2012
    544
    Enzo is rolling in his grave.
  17. therryzsx
    therryzsx Formula 3
    Dec 2, 2011
    1,358
    I think most of people here are too afraid to say it loud :D :D :D
  18. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    8,303
    Le caylar (France)
    mathieu Jeantet
    A tad exaggerating isn’t it ?:D
    TheF1BOB, ingegnere and markonex like this.
  19. Looks aside, and all things considered, I would rather have the T.50 than the F280.
    babgh, Johnny_Bravo and Chicko like this.
  20. Johnny_Bravo
    Dec 7, 2012
    544
    Totally agree.
  21. Johnny_Bravo
    Dec 7, 2012
    544
    Not at all. To say I'm dissapointed is an understatement.
  22. Johnny_Bravo
    Dec 7, 2012
    544
    Totally agree.
  23. Johnny_Bravo
    Dec 7, 2012
    544
    Hell no. LaFerrari was gorgeous, this is hideous.
    babgh likes this.
  24. gt_lusso
    gt_lusso Formula Junior
    Oct 24, 2013
    262
    Northern Europe
    I don't get it why Ferrari kept the digital start/stop button. Turning your car alive is such an important interaction, and they reduced it to a cold digital flat surface. Just like the other modern F-cars. At 3 million euros(!!!), it should have a mechanical button that you can feel with your fingertips and be able to push or turn or whatever. It should feel far more special and tactile. We experience the world through our senses, and by feeling something with our fingertips, and being able to push/pull/turn, creates a much more engaging experience.
    This is my biggest complaint about the F80. I actually thinks it is unacceptable for such a special car.
  25. evanmcm
    evanmcm Karting
    126
    Chicago
    I'm not in the market at all, but ~$4mm for a V6 and Hot Wheels styling? No thanks, I'll head over to the Pagani dealer instead. Or the Bugatti dealer...or literally anywhere else, for that matter. Both this car and the W1 do nothing for me, nothing but spreadsheets on wheels. Sure, they generate incredible numbers, but the looks, the sound, the ethos...nothing. Hell if you really want a hybrid AWD tech fest, you can pick up a 918 along with your Pagani Utopia for roughly what this costs and I think you'd have more fun. I'm sure this will sell well to eastern buyers, but I really don't think many people spending $4mm on a hyper-limited production range-topping Ferrari are quite looking for something like this.
    Johnny_Bravo likes this.
