LaFerrari tested on R&T | Page 2 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by F40 LeMans, Mar 31, 2015.
  1. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,808
    Weston, MA
    Paul
    I wouldn't believe it even if it wasn't April 1st. ;)
  2. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    149 trap speed kicks ass!
  3. Phil~
    Phil~ F1 Rookie
    3,937
    Potomac, Maryland
  4. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
  5. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,308
    This is fast. Really fast!
  6. Bronzage
    Bronzage Formula 3
    Sep 18, 2007
    1,129
    West Africa
    MJ
    Thats a great set of numbers, however I didn't see some cars on their that I would assume should be…Speciale, GTO, Pagani? Also…weird how the 599 is quicker than a F12!
    Interesting and lots of fun to go through.
    MJ
  7. Zaius
    Zaius Formula Junior
    May 8, 2014
    863
    I dunno about this wikipedia article, 458's run 10's now?
  8. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,723
    So. Cal
    Armen
    LOVE IT!!!
  9. FerrariF50lover
    FerrariF50lover Formula 3
    Aug 12, 2005
    2,383
    Ohio
    Nate
    Those are estimates if I'm not mistaken. They never did a true 1/4 test with the car. I have a hard time beliving it trapped 149 when one recently got beat up by a veyron that traps 144. It's not even close.
    https://www.youtube.com/watch?v=zkqSVm__UIU
  10. FerrariF50lover
    Aug 12, 2005
    2,383
    Ohio
    Nate
  11. supermafy
    supermafy Formula Junior
    Dec 2, 2013
    361
    Rome (it)
    I think this time (finally) are vboxed
  12. FerrariF50lover
    Aug 12, 2005
    2,383
    Ohio
    Nate
    I don't understand how it got humiliated by a Veyron then. A car that is supposedly quite a bit slower.
  13. Phil~
    Phil~ F1 Rookie
    3,937
    Potomac, Maryland
    Verdon is Awd.....and no slouch.
  14. amenasce
    34,618
    Joe Mansion
    Wet or damp conditions? If you cant go full throttle or if traction control is kicking all the time from 1st to 4th gear it will slow you down.
  15. dros1
    dros1 Rookie
    Mar 17, 2014
    13
  16. ypsilon
    ypsilon F1 Rookie
    May 4, 2008
    2,636
    the Netherlands
  17. any_1
    any_1 Formula 3
    Sep 6, 2006
    1,072
    Sweden
    is it a true production car or a car preped by the factory with tweaked computers and the works?
  18. 250 lusso
    250 lusso Karting
    May 2, 2004
    168
    As Doom had pointed out in an earlier post, the Veyron was in its top speed / low drag aero mode when it beat the LaF in that side-by-side drag race. Aero starts to play a exponentially greater role as speed increases. It can make a very noticeable difference, even with very powerful cars, above 100mph.
    In an earlier race the LaF showed a clean pair of heels to the Bug when the Bug was in normal "high downforce" mode.
    So the magazine test numbers you are referring to could easily be explained by the Bug in that test(s) being run in high downforce / high drag mode for the 1/4 mile tests.
    Beyond that, no two examples of "identical" cars are ever truly identical. The magazine test Bug may have been a less-than-optimized example, or running in less favorable air or traction circumstances. It also may have simple been "new." Many cars actually pick up a bit of performance when they are broken in with 10-12K miles. You can verify that by looking at almost any long-term test run by a magazine.
  19. Super_Dave
    Super_Dave Formula Junior
    Oct 6, 2014
    710
    Dave
    No offense but the high drag vs. low drag for the quarter mile for the veyron wouldn't make the biggest difference here. Almost certainly it is traction for the LaF on a wet track and RWD... Veyron is still extremely impressive (and may be fast 80% of the time and in most conditions).
  20. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,506
    Bournemouth, UK
    Damp track favours 4WD! Given dry conditions, the LF is faster up to around 200mph. Then the Bug's higher top speed potential takes over.
  21. F40 LeMans
    F40 LeMans Formula Junior
    Nov 23, 2009
    826
    We have to wait to know, the car is a factory car anyway.
  22. dros1
    dros1 Rookie
    Mar 17, 2014
    13
    Whats your point, captain obvious?
