Larini Exhaust System | FerrariChat
Discussion in '308/328' started by jratcliff, Feb 19, 2010.
  1. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    #1 jratcliff, Feb 19, 2010
  2. gonzo350
    gonzo350 Karting
    Apr 3, 2004
    207
    Lafayette Indiana
    Myles
    Now THAT is pretty!
  3. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Thanks, the quality of the work is excellent.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Are those headers Larinis too?
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,924
    Atlanta
    John!
    Man that stuff is like jewelry.
  6. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Yep, they sure are.
  7. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    Wow, Beautiful....
    Did you get pics of the engine (at start) of your rebuild? Cant wait to see that exhaust on.
    Good Luck, John.
  8. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Man That's beautiful, I can't wait to hear it, will you post sound and vid for us, please?:)
  9. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    This thread is useless without video....with the sound of that beautiful exhaust system!!!
    PDG
  10. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    They won't go on for at least 6-8 weeks. I have to order pistons, rods, send the cams off for regrind, etc. You can go to the Larini site and look for the Ferrari 328 video.
    http://www.larinisystems.com/video.php
  11. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    Really nice setup. Love that Polished SS
  12. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    Is your car a Euro? The reason I ask is that I have a Larini on my U.S. spec 328 and I don't see the headers as being available for any 308 or 328 U.S. variant. More fun pursuant to U.S. living...
  13. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    In some states if your car is 20 or more years old, it doesn't have to have an emission inspection. If that's the case, you could convert the exhaust to the euro spec. Personally it's way out of line price wise vs bang for the buck - I'd be surprised if you got 10 HP but certainly it's doable depending on your state and the registration status of the car - normal, "antique/classic", whatever.
    In MD, for example, where my 328 is located, the above would be perfectly OK once the car is registered as "historic." Of course, that also means that it is not supposed to be used for daily driving. Although my 328 was eligible for historic last year, I prefer keeping it as a normal registered car which means it does have to be emission-inspected. HOWEVER, they don't actually inspect it because it's too low to fit on the dyno. So they don't even open the hood, they just issue a "pass" certificate for it. :)
  14. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    It is a Euro version, zero pollution equipment. Around here (Texas) it needs to only pass a safety inspection since it is older than 25 years.
  15. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    What's the diff. between the stock headers and the Larini headers?
    Are the pipes diameter bigger on the Larini?
  16. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    I would need to measure, but I've put the stock away. Doesn't really matter though, the originals had been repaired once and were pretty rusty. Rather than fix the repair again, bead blast and then ceramic coat, I decided to go all stainless. Considering the stock FI is gone the headers will be prominent. :)
  17. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    I have to admit that even though I've tended to bash aftermarket exhausts as too loud and too expensive for nothing gained, I'm thinking of installing a Larini on my 328 and then would like to find/have made a panel that would replace the rear grill with something that would tastefully show off the Larini. Did the Euro version use the same grill as the US version?
  18. JV's89
    JV's89 F1 Veteran
    7,375
    Pittsburgh, PA
    Welcome to the dark side Mike. :)
  19. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    Actually, Mike, the Larini shows through the grills quite nicely ;-) And thanks for the insights :) Unfortuately, pursuant to smogging and such, I'm in CA; need I say more??
    Cordially,
    Scott
  20. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    #20 M.James, Feb 22, 2010
    The US-spec exhaust has both headers feeding into a single tube (Collection Pipe), which then feeds into a single Cat, which then feeds into the factory exhaust with a single input. Check the Larini again - TWO inputs, so somebody is going to have to do some 'extra' plumbing to get this thing to fit......If those smaller pipes can plumb directly from the headers to the Exhaust can, then you're all-set.
  21. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    I think you should read the whole post. The car is an 83 Euro and the stock exhaust do not feed into a single input on a euro car.
  22. dinonz308
    dinonz308 Formula Junior
    Nov 26, 2017
    869
    Dean
    Sorry to resurrect a decade old thread - but I wanted to confirm - it's possible (easily) to convert the US exhaust to a complete euro system - all the mounting points are the same, or does it require fabrication to add/modify mounting points?
