Larini / Tubi side-by-side header comparison | FerrariChat
Discussion in 'Technical Q&A' started by snj5, Mar 22, 2007.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #1 snj5, Mar 22, 2007
    Since I bought both (Carobu graciously took the Larinis back - kudos) Larini and Tubi s/s headers for the 3.2 and qv, here is a unique look at these high end performance headers side-by-side.
    The Larini headers are polished stainless steel, which looks spectacular -- but important to remembered that polished s/s may discolor after a few heat cycles. Overall the headers are a Tri-Y 4 - 2 - 1 design with differing length secondary tubes as shown in the photo, designed to spread the torque curve. The mounting flange is a piece of flat sheet steel with the oval qv ports to which the tubes appear to be slightly bent to fit and welded. The quality of the exterior welds is good, but there was some rough edges inside the flange. In the primary tubes there were noticible 'kinks' and narrowing in the tubing where it had been bent, some pretty extreme - some of these are circled in the drawing. While spectacular on first glance, the tubing kinks and flange mating ultimately made the Larini unacceptable for me.
    The Tubi headers, which took months of waiting, were the opposite - not so impressive on first glance as it was not polished - but upon closer examination showed worth. Also a Tri-Y, the big difference in design to the Larini was the lack of secondary tubes on the rear header -- the collectors just went into the other. The flange was a nice cast and reinforced piece with a specific venturi-like mating surface and cast leaders into the primary pipes - very nice. The tubing looked to be hydrauically or mandrel bent - no kinks or deformations anywhere. The welding around the collectors also looked first rate. The Tubi also had the heat shield mounts, which the Larini did not - details, details.
    The lack of polishing for me is n/a, as they will be ceramic coated.
    I kept the Tubis - quite a bit more expensive, but it does look like you get what you pay for. The Larini headers were a bit surprising as their silencers are so very well done, I'm told. Again, kudos to Carobu for taking them back on their own suggestion.
    Hope this is interesting for some.
  2. f355spider
    f355spider F1 World Champ
    18,053
    Great information Russ. How so the heatshields mount onto the Tubis? On the oem 355 exhaust headers they are spot welded in place.
  3. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    What about prformance? Did you have a chance to test one and the other?
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Will have some numbers on the Tubi in a couple of months, but the Larini never was installed.
    If anyone is interested, the Larini is still unused at Carobu, & much less expensive than the Tubi.
  5. testarossanera
    Jul 11, 2004
    8
    I need headers for my 355. One side is cracked.
    Jason
  6. f355spider
    18,053
    Jason, do a thread search, there are many, many threads on solutions to your common problem.
