Laser Digital Thermometer | FerrariChat
Discussion in 'Australia' started by Aircon, Jan 8, 2011.
  1. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I just bought one of these things and noticed something strange. I aimed it at the cup warmer on my coffee machine and it reads 25deg..which is clearly wrong because it's quite hot to the touch. All the plastic around it is 50+ degrees, which makes more sense.
    This lead me to wonder how accurate it would be at measuring brake disc temperatures if the metal on my coffee machine gave such an erroneous read out.
    Anyone know for sure?
  2. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    I used one when racing on tyres and brakes,most welcome to try it.
  3. Aircon
    100,524
    Peter
    Thanks for the response and not answering the question :p
  4. Arvin Grajau
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    so you don't want to compare readings?
  5. Cribbj
    Cribbj Formula 3
    They don't work all that well on smooth or shiny metal; it confuses the laser.
    Dark or rough surface readings should be fairly accurate.
  6. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Brett
    Its called emissivity PP. Google it. If you search that word here on Fchat you might find a post I did showing a tool. I painted part of the surface with matt black paint. The tool was as 57 degrees. When aiming at the painted bit it read 57 and yet when I aimed it at the non painted aluminum surface it read 36 degrees.
  7. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Brett
  8. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    My experience with them when using them in HVAC applications is that they aren't very accurate.Basically will only tell me if something is hot or cold
  9. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,626
  10. Aircon
    100,524
    Peter
    costs money and he's a tight arse.
  11. Aircon
    100,524
    Peter
    thank you. i'd have felt ripped off with this thing if it hadn't only cost $8.11
    it seemed spot on when measuring inside the fridge, the oven and other flat coloured objects.
    bloody useless for brakes though I'd say.
    Also measured air from my a/c vent reasonably well too but i assume that's only because the cold air cooled the metal air outlet.
  12. XTREMEIND
    XTREMEIND Formula 3
    Mar 8, 2010
    1,270
    Showbag
    I use one with my model aircraft engines which have cast painted cylinder heads and it appears to be quite accurate, the readings I get are very simular to what the German manufacturer gets on a purpose built test dyno.
  13. mhh
    mhh F1 Veteran
    Feb 16, 2004
    5,894
    Australia
    Mark
    Hey, a gadget I haven't got. :p
    What are they for and where do you get them?
  14. Aircon
    100,524
    Peter
    lol
    you're a funny boy :)
  15. Buxton
    Buxton Formula Junior
    Oct 31, 2010
    484
    B Buxton
    You might be using it for the wrong application.
    Are these intended to measure external temperatures or where the sun doesn't shine?
  16. 275 GTB
    275 GTB Formula 3
    Nov 21, 2008
    1,337
    Sthrn Highlands
    Hmmmm maybe he needs a rectal thermometer then.....
  17. SPEEDCORE
    SPEEDCORE Four Time F1 World Champ
    Jul 11, 2005
    46,182
    Toe Knee
    Did your laser digital thermometer cost $5 from China ?
    Might explain why it's crap :p
  18. Aircon
    100,524
    Peter
    it's not....it seems to do exactly what they usually do, which is......not what a lot of us would want to do with it.
  19. EfiOz
    EfiOz Formula Junior
    Jul 26, 2005
    850
    Lago di Legana
    Lucivius Maximus
    We sell seperate IR's for brake or tyre, but not both. The two main differences are temp range and emmisivity settings. The brake one is cal'd for bright steel.
  20. Aircon
    100,524
    Peter
    i reckon that's where mine is let down, not that i bought it for that.
