Latest pictures of MM Enzo | Page 11 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by S Brake, Jan 17, 2009.
  1. Dilancer
    Dilancer F1 Rookie
    Jan 28, 2007
    3,388
    Los Angeles
    Dilan B.
    What a thread! Would love to see this car at the Texas Mile next month. But I believe theres still a lot of work to be done. Keep us posted on the updates! Thanks!
  2. atomicskiracer
    atomicskiracer Formula 3
    Mar 30, 2005
    1,736
    Ryan
    We need an update!!
  3. FerrariF50lover
    FerrariF50lover Formula 3
    Aug 12, 2005
    2,383
    Ohio
    Nate
    With all do respect Jim there's a lot of cars that will most likely produce more hp and use a smaller tire and have a front engine layout that have traction. I immagine if he goes to a softer tire compound like that in a slick or a radial he will be fine. But this All depends on how much hp he will make and what the powerband looks like.
  4. NWaterfall
    NWaterfall Formula Junior
    Aug 2, 2009
    564
    The Track
    Waterfall
    +1 !
  5. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    In the case of the Enzo with the HP that a stock one has on it's stock tires it comes on the TC from a dig so I'd think with more HP the situation would be worse.
    Are you talking about AWD cars? The Veyron even with it's larger and better tires comes on the TC from a dig with it's 1000 engine and it's AWD.
  6. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    Not a bad idea, but the Veyron's tires are reportedly north (in some instances, WAY north) of $10K. And any 1000 hp car, AWD or not, is going to go through them fairly quickly.
    I know that money probably isn't an issue here, but it seems like there could potentially be a better alternative.
  7. rossocorsa13
    Jun 10, 2006
    2,557
    M
    Jim, any problems with traction once out of first gear on P4/5? Obviously a twin-turbo Enzo will have more issues than your car, but I know P4/5 has less weight to deal with as well.
    And you are running wider tires than stock Enzo, correct?
  8. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The issue becomes the wheels as well. I'm not sure bigger tires and wheels will go on a stock Enzo without some modification including modification to the ecu which we had to do when we fit bigger wheels and tires to P 4/5.
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #259 Napolis, Sep 18, 2009
    Yes even with bigger wheels and tires we come on TC in second gear as well.
  10. FerrariF50lover
    Aug 12, 2005
    2,383
    Ohio
    Nate
    #260 FerrariF50lover, Sep 18, 2009
    More along the lines of drag cars Cars have gone 7's on 275's. I immagine this car wont be used so much as a road race car anymore more of a driver. So the suspension might be adjusted differently then a stock enzo. If he plans to run a slick type tire for traction purposes it could very well hook from a dig with a little heat in the tire not to mention be very potent from a low mph roll. The turbo Ford GT's are praised for their traction on the street, I immagine this enzo will be the same way. It also depends on how they run boost and how much lb is in each gear. With modern boost controllers each gear can have its own boost setting. For example say max boost is 20lbs first gear could be set at 6lbs second gear 15lbs and 3rd gear on would be 20lbs. With that said we will have to wait and see how much hp the car produces. Once the turbos are announced that will be easily figured out.
  11. rossocorsa13
    Jun 10, 2006
    2,557
    M
    Drag cars run 7's with 275's on tracks coated in loads of rubber and suspensions set to run in a straight line. A twin-turbo mid-engine V12 supercar probably won't have the same objectives, nor is it likely to be set up that way.
    I can't imagine that hooking up from a dig is that important--1000hp takes quite a toll on a transmission/drivetrain when transferring all that energy into forward motion from zero...Not to mention that once a car dips below the 3.5 second range from 0-60, there really isn't much left to be found unless you're strictly drag racing because traction is so difficult to obtain. Hooking up in third while flooring it will probably be a bigger issue.
    I also would guess that Mr. Losee won't run a slick tire due to his extensive history of driving the car on the street (a reported 35K + miles prior to the wreck). Not only are slicks illegal (to my knowledge), but they are incredibly dangerous when combined with any amount of water.
  12. GLEXPilot
    GLEXPilot Rookie
    Apr 20, 2009
    31
    Chicago, IL
    Amazing work, I want to see how this one turns out.
  13. Detailing Technology
    Sep 10, 2009
    44
    White Plains, NY
    Justin
    I remember reading about a Beryllium bicycle frame somewhere. The cost of the frame alone was allegedly in the $20k range.
    I'm amazed at the strength of the carbon where it mates to the cage. You'd think the metal would be more rigid and "snap" the carbon when stressed.
  14. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    It's a plated sandwich.
  15. modena1_2003
    modena1_2003 F1 Rookie
    Aug 17, 2005
    3,954
    Jon
    Though, I prefer mine on a paper-towel honestly... Much more humble.
    _J
  16. drew138
    drew138 Karting
    Jul 31, 2006
    148
    #266 drew138, Oct 4, 2009
    Isn't this how this whole project got 'started' in the first place?
  17. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    When will this Puppy be up and about???
  18. rossocorsa13
    Jun 10, 2006
    2,557
    M
    #268 rossocorsa13, Oct 5, 2009
    Yowzers...easy there. :)
  19. Pantera
    Pantera F1 Rookie
    Nov 6, 2004
    4,479
    Just make sure you use all those horses when you get it back on the road ;)
  20. NWaterfall
    Aug 2, 2009
    564
    The Track
    Waterfall
    #270 NWaterfall, Oct 5, 2009
    Without pics it didn't happen?..... :D
  21. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #271 Napolis, Oct 5, 2009
    You very much want to ceramic coat those.
  22. FerrariF50lover
    Aug 12, 2005
    2,383
    Ohio
    Nate
    How are the turbos mounted? What mm are they?
  23. Chris Barnett
    Chris Barnett Rookie
    May 11, 2009
    45
    Who are you guys using for the ceramic coatings? I've always had good results with Swain coatings on race cars.
    I've seen/tested a coupe different ones, and the only common factor is this: don't coat the inside of the manifolds. I've seen a couple destroyed turbochargers because of the coating flaking inside the manifolds, and with the price of an enzo engine, safe is better than sorry. :)
  24. technom3
    technom3 F1 World Champ
    18,586
    Phoenix AZ
    Justin
    you guys need to do a little reading on 1200-1500hp "street" cars. these cars that run 7' and even 8s... can be driven on the street with the way there suspension is... go take a look at supraforums.com and read. PS. i hate the supra, and just about every single supra owner (stereotypes suck) but... amazing things have been done with these cars... a gentleman who goes by the name of SW should be the focus of your search... hit TT gallardo was just completed and he will be putting a motec on it shortly... it should then produce over 1500hp to the tire... the tire... not at the flywheel...
  25. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,485
    Austin, Texas
    Michael C
    SW (aka Streetking) is a member here on FChat. We will be at the Texas Mile next weekend. It will be interesting to see what what the TT Gallardos can do. Jonah's is already producing 1500whp, not sure about SW's.
