launch X431 mini pro question | FerrariChat
Discussion in '360/430' started by spider348, May 1, 2021.
  1. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Does the Launch X431 mini pro have the capability to read and bleed the Bosch 5.3 ABS module in a 360? My current off-brand tool has the latest Ferrari 10.95 software(Diagzone). Menu for the 360 shows no brake selection. Strange because 430 system is shown as well as 355.
    Hoping to finish my brake service with a complete flush and bleed.
  2. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,226
    Shorewood, MN
    Kevin
    I also have the Launch device. I've read that it is possible to bleed the 360 brakes using the device, but in the end never tried it. Using the Motive pressure tool was just too easy to pass up.
    Kevin
  3. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Thanks Kevin. Odd there is no brake system selection for the 360. Most other models show the brake system as available.
    The Power Bleeder will not service the ABS reservoir. Needs to be cycled via tool.
  4. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,226
    Shorewood, MN
    Kevin
    Yes, unfortunately the Launch device is somewhat limited when it comes to the 360. I initially bought it to use with the CS TCU I bought, and it worked well for that purpose.
    By chance, have you tried to use the brake system selection under the 430? Just wondering if there is any way that would function?
    Kevin
  5. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,425
    Santa Clarita, CA
    Does the 360 have ABS? If it doesn’t, maybe that’s why it’s not listed.
    Sorry if it’s a dumb question, I have a 430 and don’t know much about the 360.
    Just trying to help.
  6. Skippr1999
    Skippr1999 F1 Rookie
    4,514
    Just flush all the other brake fluid and go for a drive. Find a gravel area and slam the brakes ( going slow !). This will activate the ABS system and mix enough fresh brake fluid to make things “good enough”.
    flash32 likes this.
  7. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Thanks Skipper1999. That is my plan. Cycle the ABS then bleed again to remove downstream old fluid. Just curious why the Ferrari 10.95 software does not show the brake option on my tool!
    Skippr1999 likes this.
  8. mferrari43
    mferrari43 Karting
    Jan 23, 2022
    127
    California
    Matthew Ferrari
    anybody find a tool that will work to bleed the ABS on a 360?
  9. Peter550
    Peter550 Rookie
    May 8, 2014
    37
    germany
    I also use an X431 with software version 11.10 and it doesn't work with that either. Apparently there is a software update to 11.35. Does anyone know anything about it?
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,586
    San Carlos, CA
    Mitchell Le
    I never needed to bleed the ABS....
    Why are you doing that?
