Lawn Mower repair HELP | FerrariChat
Discussion in 'Other Off Topic Forum' started by jimpo1, Dec 31, 2015.
  1. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,903
    Dallas, TX
    Jim E
    I have an old Honda lawn mower that would start but not run. It's happened before and has always been a gunked up carb problem. My mechanical skills are limited, and I really don't want to spend $80 to have my 20 year old mower repaired. I have others but the Honda is a favorite and I don't mow much. Rather than pay to have it rebuilt again, I bought a brand new carb and put it on.
    Same problem. Will start, but won't run. I know its not the carb! It acts like its not getting gas, but the fuel system is pretty simple: a tank and a line to the carb. Both are fine.
    Thoughts?
  2. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    Vent on cap of gas tank plugged? This would explain it if it took a few minutes to die
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    There is often a screen inside the fuel tank where the outlet hose is fitted, and this can become restricted due to contamination in the tank (grass/rust/etc.). You might want to just unhook the fuel line from the carburetor, put some gas in the tank, and open and close the fuel shutoff valve a few times. Is fuel actually flowing through the hose? It's gravity feed, not from a pump, so it needs to be clear.
  4. JasonMiller
    JasonMiller F1 Rookie
    3,649
    Co Springs/ Texas
    Jason Miller
    Yes! You are having a venting issue, just bring it over to my house and I will fix it right up. :)
  5. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    I have seem the intake valve start to stick in the guide on a few of the older Hondas. Adding Techron to your fuel helps to keep the stems clean. Also might want to chec valve clearances.
  6. zudnic
    zudnic Formula 3
    Nov 13, 2014
    1,896
    Vancouver
    #6 zudnic, Jan 1, 2016
