Lead additive, Yes or No? | FerrariChat
Discussion in 'Technical Q&A' started by alnimmob, Aug 10, 2013.
  1. alnimmob
    alnimmob Rookie
    Oct 20, 2007
    2
    Fort Lauderdale, Fl
    Albert Niels
    Hello,
    I own a 1984 512 BBi not federalized.
    My question is if i use no ethanol fuel is it still beneficial to add lead in it and if yes, what is the best brand for lead additive product?
    Thank you so much, please if you can email your answer at [email protected]
    Best
    Albert
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    No benefit that I'm aware of.
  3. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    What would be the purpose? The compression ratio is not really very high...
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    As long as the gasoline has enough octane, you don't need lead
  5. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,036
    Barrington Hills, IL
    Daryl Adams
    Supposedly the lead in older fuels provided a buffer between exhaust valves and their seats. The thought was that a hot exhaust valve would have microscopic spots that would actually weld themselves to the face of the seat. When the valve pulled away from the seat those teensy tiny welds would break, over time leaving a rough surface that would cause valve recession. The lead in the exhaust gasses was said to prevent this from happening. How important is it? Who knows. I just add the lead substitute for peace of mind. I use Redline, as it's concentrated and seams to go farther.
  6. Jdubbya
    Jdubbya The $10 Trillion Man
    43,674
    Hell's waiting room
    If you have a car that is designed to run on unleaded why use a lead substitute. A car designed to run on unleaded should have hardened valve seats so the extra precaution is probably just a waste of money.
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,919
    Richmond
    Pete
    It's fairly important on cars that do not have hardened exhaust seats and haven't had lead pounded into them for a lot of miles - ie old, low mileage muscle cars are known to pound their exhaust valve seats in and some older VW's have the issue as well. I doubt it'd be an issue on a 512BB or any other aluminum headed engine as they have seat inserts that should be fairly hard. That said, I have no idea on the metallurgy of them and Ferrari are known to not always use the right material for the job...
  8. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    Can you buy lead additive any more? I've never seen it, but then again I've never looked either. It certainly doesn't seem like a bad idea to run leaded gas at least occasionally for cars built in that era given the valve seat concern. I've seen "lead substitute" additives, but have no idea if they have the same beneficial benefits on valves/seats.
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It's available but not necessarily the same stuff that was originally blended into the gasoline. I've heard complaints of sticking valves from using lead-substitute additives
  10. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    There is some good info here: Lead fuel additive
    According to a poster on that thread, the TEL (Lead) has some issues itself in addition to being highly toxic. It is still available from one manufacturer, but will soon be shut down. The discussion suggests Redline lead substitute helps the valve issue.
    I'd be interested in hearing more about issues with lead substitute additives -- they were sounding pretty good to me after reading that AACA thread.
  11. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
  12. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    lead -tetra-ethyl lead-has one function in gasoline as an additive, from a chemistry perspective: it is an ANTI-DETONANT.
    period
    if you have pre-ignition, pinging under load...that is what its for...
    it has no capacity for increasing the BTU f the fuel-ergo, your cars engine will not "runn better and burn hotter, and make more power"
    2nd law of thermodynamics: there is NO free lunch
    Whart leads intent is, is to make sure there is a controlled flame front, as opposed to an "explosion"-detonation. The forceses involved on engine parts-pistons, rings, etc, is a 20-30X difference with pinging!
    The lubrication of valve seats is an unquantifiable, secondary, unintended consequence, and mostly an old wives tale-speaking from the perspective of the true nature of whats going on iside your engine.
    Don't waste your time and money on voodoo in a can...better spent on a competant mechanical practitioner....
  13. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    I don't care about cost -- any additive is about 0.000001% of the cost of maintaining a Ferrari so it is a non-issue. I also don't care about anti-detonation. I do care about the lubrication properties and eliminating the potential for "mini-welds" that lead and substitutes are reported to prevent because that seems important. I (and I suspect the OP) am/are not considering additives in lieu of a mechanic - I have zero mechanical issues but I share the OP's desire to understand the best way to treat the engine so that it runs its best and is operating under the most favorable circumstances for how it was built. Whether the lubrication benefit of lead was intended or not isn't really relevant, the important point is whether lead actually was a lubricant and whether it is beneficial to try to duplicate that today in older engines.
  14. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,273
    Gold Coast, Aust.
    Patrick
    Actually, the second law is: "You can't win, you can't break even, and you're not allowed out of the game"
