Leak at the top of the rear shock absorber | FerrariChat
Discussion in '348/355' started by judd10, Sep 14, 2007.
  1. judd10
    judd10 Formula Junior
    488
    Seattle, WA
    #1 judd10, Sep 14, 2007
    I've had my '99 355 F1 for about six months now and just noticed some oil at the top of the rear driver's side shock absorber. I wiped it off the other day & it looks like a little more oil leaked out. Does anyone know what might be causing this? Is this a serious problem/will it be very costly to repair? Just trying to prepare myself for my next repair bill :) Appreciate any words of wisdom! Judd
  2. fastmikey
    fastmikey Karting
    Aug 11, 2006
    111
    Auckland
    Mikey
    I have a 95 355 berlinetta and I noticed the same thing about 8 months ago. I had them rebuilt - and now it drives like a new car. Well worth the hassle. Delta Vee (who are a site sponsor) do them and also if you are in the australasian part of the work pm me.
  3. 355Aussie
    355Aussie Formula Junior
    Jul 3, 2007
    688
    George
    I had the same issue. The shocks are on the way out. You can still drive it OK no problems but eventually it will just get worse and worse.
    I had them redone(not replaced) and they are OK now. I did both so they could be reset equally and match.
    It wasn't that expensive compared to other bills I have paid. Around $1500 Aussie dollar for both sides.
    Good luck
  4. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    With the bushings wet with oil the shock's been leaking for a while; though it's a small leak, the shock is pumping oil out a little at a time with every movement. Ignored for years, I've received shocks virtually emply of hydraulic oil for rebuild. Typically shocks arrive about 20 - 40 ml lost out of a total of about 270 ml when recieved for rebuild.
    Cost for rebuild is $290.00 each and policy is rebuilding a minimum of one axle set at a time to maintain balanced handling.
    We also offer a core exchange program for the F355 when down time must be kept to a minimum. We suggest scheduling your rebuild with us for the same reason; with proper timing, turn around can be as little as one day.
    Best,
    Rob
    www.deltavee.net
  5. judd10
    488
    Seattle, WA
    As posted earlier, one of my rear shocks is leaking. I visually inspected the towers of the front shock absorbers and they appear dry (no leaks). This winter I plan to have delta vee rebuild my rear shocks and then get an all wheel alignment. How long do these shocks usually go before needing a rebuild/replacing? I have 16K miles on the car & it is a 1999 MY. I am wondering if I should go to the extra expense of getting the front shocks rebuilt at the same time as a preventative measure? Is this advisable or wasting $? Any advice from the group? Thanks, Judd
  6. fastmikey
    fastmikey Karting
    Aug 11, 2006
    111
    Auckland
    Mikey
    If youre doing one end you may as well do the other for more than one reason . . . you won't regret it!
