Leak down test on 550 | FerrariChat
Discussion in '456/550/575' started by willy_rosenberg, Mar 24, 2015.
  1. willy_rosenberg
    willy_rosenberg Rookie
    Mar 14, 2008
    24
    New York
    Willy Rosenberg
    I recently had a complete service done on my '99 550 maranello. It included the timing belts (at 24,100 miles), and a leak down test was performed as well at my request. I do understand the concept that the gauge shows the loss percentage which indicates the condition of the cylinder and overall condition of the engine. The less the “loss” percentage the better the condition the engine is in.
    Based on the individual readings I got, I have the following questions:
    1) In general, the findings show a loss percentage below 10% which indicates that my engine is in great to good running condition.
    --> Is that a correct statement ?
    2) In particular, there appear to be great variances between the single readings.
    - cyl. # 1, 2, 3, 6, 8:____9%
    - cyl. # 4:____________7%
    - cyl. # 5, 9:__________4%
    - cyl. # 7:____________5%
    - cyl. # 10, 11:________11%
    - cyl. # 12:____________8%
    There is a great inconsistency (high to low) in leakage of 63% between cylinders 10, 11 and cylinders 5 and 9.
    --> Anything to be concerned about ?
    3) Let’s assume that the above variances are of no consequence, it looks like cyl # 10 and 11 (both over 10%) are going to create a problem sooner than later.
    --> Is that a fair assumption ?
    4) Based on the above, would anyone be able to give me an opinion as to the condition of my engine (i.e. rings, valves, and head gasket) ?
    Thanks.
  2. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,006
    socal
    At this time i would not worry about it. The readings are a controversial snap shot in time of a dynamic system. It is like your arm hurts and the doc only takes 1 xray. He has got some data but it must be used in context with the rest of an exam before a conclusion can be drawn. More digging needs to be done before anything meaningful can be said. Drive the car and enjoy it. The numbers are not great but do not warrant more intervention. The 550 is not the 355 with known valve guide issues.
  3. henryr
    henryr Two Time F1 World Champ Silver Subscribed
    Nov 10, 2003
    22,414
    Atlanta
    Juan Sánchez Villa-L
    think you should probably looks to sell it asap
  4. flyboyx
    flyboyx Karting
    Dec 19, 2014
    70
    Houston, Tejas
    brian
    lol
  5. willy_rosenberg
    Mar 14, 2008
    24
    New York
    Willy Rosenberg
    Wanna buy ???
  6. henryr
    Nov 10, 2003
    22,414
    Atlanta
    i will buy anything at the right price......
    post up the info or pm me
  7. willy_rosenberg
    Mar 14, 2008
    24
    New York
    Willy Rosenberg
    Not selling. Just trying to get some tech info ;-)
  8. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Willy, done hot or performed cold? Makes a big difference on the readings. You want hot.
    Did the mechanic who performed the test indicate if it was leaking through the valves or past the rings?
    Philip
  9. willy_rosenberg
    Mar 14, 2008
    24
    New York
    Willy Rosenberg
    Performed @ cold. No word on "leakage" as it passed without comments.
    Wanna get really technical ?
    Does the following comparison entice you to a comment?
    --> Leak Down (comparison @ cold) <--
    March 2015..................November 2011
    @24,158 miles.............@13,063 miles
    - cyl. # 1:____9%.........10%
    - cyl. # 2:____9%.........10%
    - cyl. # 3:____9%.........10%
    - cyl. # 4:____8%.........10%
    - cyl. # 5:____4%.........6%
    - cyl. # 6:____9%.........7%
    - cyl. # 7:____5%.........5%
    - cyl. # 8:____9%.........4%
    - cyl. # 9:____4%.........11%
    - cyl. # 10:__11%.........12%
    - cyl. # 11:__11%.........10%
    - cyl. # 12: ___8%.........11%
  10. fatbillybob
    Aug 10, 2002
    29,006
    socal
    My comment stands. You just proved it. You got 4years 10,000 miles of enjoyment and little variation. Keep driving it.
  11. willy_rosenberg
    Mar 14, 2008
    24
    New York
    Willy Rosenberg
    Thank you for your time and your encouraging words. I will (I do) enjoy every driving moment.
