Leak in bottom of 1999 355F1 trans..help indentifying please! | FerrariChat
Discussion in 'Technical Q&A' started by campbell53, Nov 21, 2006.
  1. campbell53
    campbell53 Karting
    Oct 5, 2006
    96
    #1 campbell53, Nov 21, 2006
    I just got the car and had the 30K (plus clutch) done at a F dealer before delivery. I have a very light leak from an inspection type plate in the middle of the trans bottom. There is some type of plug/sensor (trans temp or level?) coming out of this recessed area. Can anyone tell me what the plug does and if this is something typical and/or easily repairable? Thanks a million as I don't know enough about the car yet so self diagnose.
    I attached a pic of the area and you can actually see a drip of oil ready to ruin my floor.
  2. Rifledriver
    37,108
    The component is a transmission shaft speed sensor. It hangs VERY low and is often banged against the ground breaking the cast aluminum plate it is attached to. Yours has been repaired at least once.
    Order a new plate and gasket from Ricambi and next trans oil change replace it.
  3. campbell53
    campbell53 Karting
    Oct 5, 2006
    96
    Thanks...this has been driving me nuts. I appreciate your help. Daniel will be my next move.....
  4. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Very smart to fit that shaft speed sensor there. :p:p
