430 - Leak off the passenger side? Potentially fuel?... | FerrariChat
430 Leak off the passenger side? Potentially fuel?...
Discussion in '360/430' started by iheartf430s, Aug 24, 2024.
  1. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    I took my daughter's friend on a bit of a spirited ride. Short loop with a few straights, where I let the revs run up a bit, some twisties, and a bit of semi-hard braking. Still all reasonably mild. I also made sure the engine and oil was up to temp before pushing the car a bit.
    I pulled in, let the car sit a bit before pulling in the garage. I noticed a little streak of fluid.
    I smelled it and touched it and it smells like gas, but has an oil feel to it.
    I've attached some pictures
  2. LorenzoR
    LorenzoR F1 Rookie
    what side of the car
  3. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    Right side, passenger side
  4. LorenzoR
    LorenzoR F1 Rookie
    I'd be looking just to check the top of the fuel pumps and also the f1 fluid in the right rear fender
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,923
    Central NJ
    Dominick
    What color ...use a tissue to see color
  6. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    But
    Hey Dominick, I was actually gonna text you, but didnt want to bug you on a Sat night.
    There is not enough fluid to sponge up. I tried and it's already evaporated or sucked into the concrete
  7. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    By the way. The fluid that sprayed off the tire, is the front passenger side
  8. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    I took the panel off and took a few pictures.
    Definitely some fluids on this thing
  9. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    That thing is your F1 reservoir. If that’s where the leak is coming from, it’s probably overfilled. With the aggressive driving the fluid got hot and overflowed a little. It’s an easy fix, just lower the fluid. There’s a procedure that’s been previously posted.
    Flash can fill you in further.
    This leaking is WAY better than your fuel pump leaking. Confirm that your fuel isn’t leaking by checking the top of the pump under the right side cover in the engine compartment.
    imahorse and LorenzoR like this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,923
    Central NJ
    Dominick
    Call me tomorrow afternoon
    iheartf430s likes this.
