Leak question! | FerrariChat
Leak question!
Discussion in 'Technical Q&A' started by raminjulian, Mar 22, 2022.
  1. raminjulian
    raminjulian Rookie
    Feb 26, 2022
    8
    Julian Yu
  2. SeattleStew
    SeattleStew Formula 3
    1,018
    In the rain
    Stew
    Could be gear box oil or clutch fluid, unlikely to be engine. The obvious recommendation is to have your local dealer take a look if under warranty. Otherwise might want to drop by a ferrari mechanic for further inspection.
  3. windsock
    windsock Formula 3
    1,142
    That looks to be a soot and water mixture which is common on direct injected vehicles. It is likely leaking from the exhaust joints once cold.
    Still worth having the dealer look at it. they can seal those joints to prevent it from happening.
  4. Rifledriver
    36,890
    #4 Rifledriver, Mar 23, 2022
    He said it was clear but oily which is kind of consistent with what I see. Id never call condensate oily and the dirty floor is what I thing you are seeing, not soot. You might be right but I have never seen someone describe water as oily.
  5. windsock
    windsock Formula 3
    1,142
    We had to take apart dozens of exhaust systems when the California first came out and use muffler cement to seal joints for this very reason. Later cars came from the factory with joint sealer already in place. The other location that may be leaking from is the shaft for the exhaust flaps, no way to seal that. The direct inject cars make a lot of soot. Its why the newer cars have been required to add GPF (Gas Particulate filter) filters in the exhaust to trap and burn off the soot during the regeneration cycle.
    tbakowsky and SeattleStew like this.
  6. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,394
    Santa Clarita, CA
    When does the puddle appear?
    The moisture from the exhaust will not be there right after a drive and the exhaust is hot.
    If it’s there in the morning when the exhaust has cooled and attracted moisture, that’s probably the issue.
  7. SeattleStew
    1,018
    In the rain
    Stew
    To add my experience with the sooty exhaust, I never had a sooty puddle under my car, but I did notice the dried up soot on the ground. This happened when I swapped in an xpipe and didn't use the Italian elmers glue to seal up the joints. After sealing the joints it doesn't create soot spots under the xpipe.
  8. raminjulian
    raminjulian Rookie
    Feb 26, 2022
    8
    Julian Yu
  9. ridege55
    ridege55 Formula 3
    1,383
    Manhattan Beach, CA
    I had a leak in the same spot with my 458. It turned out to be gearbox oil, leak was coming from O ring and line.
  10. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,876
    The Cold North
    Tom
    DCT oil kinda looks like apple juice..I wouldn't be driving the car until it's checked out.
  11. windsock
    windsock Formula 3
    1,142
    That is definitely more significant then any exhaust issue.
