Leak underneath clutch - help | Page 3 | FerrariChat
Discussion in '348/355' started by AceMaster, Sep 4, 2010.
  1. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #51 AceMaster, Sep 14, 2010
  2. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #52 AceMaster, Sep 14, 2010
    As Ernie shrewdly advised us in his thread, we do not want the muffler being held up by the cats, so the next step was to use the floor jack to support the muffler before I removed the fasteners on the bracket that hold the muffler up.
    By the way, do you like my matching floor jack and jack stands? Nobody can accuse me of not being colour coordinated (actually, believe it or not I did not plan the jack and stands to be yellow, it is pure coincidence :D:D honest)
  3. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #53 AceMaster, Sep 14, 2010
    Next step, I removed the bolts inside that bracket that fasten the muffler in its place. These are both 13mm fasteners, so you will need either two 13mm sockets or a 13mm wrench and a 13mm socket. Of course there is one on each side of the muffler, but I only took a pic of the one side (left side) because I know the 348 Brotherhood ingenious :D
  4. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #54 AceMaster, Sep 14, 2010
    No worries Ernie, I got your back on this one :D:D
    Inspection plate consists of four 8mm nuts.
  5. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #55 AceMaster, Sep 14, 2010
    This part I had a tought time with. It was more cumbersome than it was difficult, and here is where removal of the bumpe would have been a tremendous benefit. Nevertheless, my will and determination got me through it.
    Removal of the fasteners for the muffler to the cats, 13mm on each side and you will need a wrench on both, otherwise you will be spinning perpetually. One on the bottom, one on the top for each side of the muffler
  6. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #56 AceMaster, Sep 14, 2010
  7. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #57 AceMaster, Sep 14, 2010
  8. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #58 AceMaster, Sep 14, 2010
  9. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #59 AceMaster, Sep 14, 2010
    Now simply just go around the bell housing and remove each bolt, there is a total of eight bolts, and a 13mm socket is what you will need for this procedure.
    You do not remove this one located in the top right corner when facing the bell housing from the rear of the car (Ernie is pointing to it with a bolt).
    Again, credit goes to Ernie for pointing this out and this is his picture.
  10. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #60 AceMaster, Sep 14, 2010
  11. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #61 AceMaster, Sep 14, 2010
    So here is the bell housing, I have no clue what to do next (what have I done - paging ALL stooges, paging ALL stooges, need DIRE assistance :D:D)
    I had a quick peak inside as it sits there, there is fluid in there right at the spot where that red arrow is pointing, but I do not know what it is....however with that said I would think that is perfectly normal as there should be some fluid in there.
  12. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #62 AceMaster, Sep 14, 2010
    A look at the condition - there is grease all over that, it is not even close to being as clean as Ernies. Also, the triple seals do not appear to be leaking but I will take Ernie's advice and change them now while that thing is apart (it's gonna have to be done soon anyways).
    Pic # 4 is Ernie's, I posted it to compare how clean his is to mine. I am not sure if that grease mess in mine is a bad thing, or a sign that something is splattering grease and it shouldn't be...I will need an expert to tell me what's going on.
  13. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,269
    Huntsville, AL., USA
    Andrew
    Brave stuff, Mike. :)
    Just wondering... is there any particular reason it seems shiny from 2 O'clock to 6 O'clock and brown elsewhere? Or is that normal/inconsequential or just the camera flash?
    All the best,
    Andrew.
  14. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #64 AceMaster, Sep 14, 2010
    I couldn't get a good angle on the TO bearing, but from what I can see there is nothing wrong with it physically, it is still all in one piece - by that, I mean that it looks nothing the one I saw in a different thread where someone posted a "blown out TO bearing". I may need to remove it to inspect it better but I will not dare touch anything else until the Stooges advise me on what to do next.
    So I sit here and wait....
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    THATS WHAT I'M TALKIN BOUT!!!
    Way to man up and gitterdun Mikey!!!!
  16. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    So far it looks as though the seals in your throw out have had it.
    How does the back side of it look? Is the back end blown out, or is it in once piece?
  17. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    You can say that again - I have never worked on any car - that's right, ANY car, let alone a Ferrari...unless oil changes count :D:D. But with the encouragement of everyone who posted here, and that 45-minute conversation I had with Ernie, I suddenly grew a set of "Ferrari Tech Balls" :D:D :D
    Do you mean pic # 4? That is Ernie's, so I am not sure. If you mean pic 1 or pic 3, that is mine, and it would be from the flash as the grease is about evenly spread out except along the bottom where it is heavier or greasier than the rest.
  18. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #68 AceMaster, Sep 14, 2010
    Ernie, from what I can see it is still in one piece, not blown out or cracked, not even a scratch on it. But I still would like to take it off to have a look at the back of it, is that possible?
    Also, is that grease all over the place (more heavy along the bottom) a cause for concern, or is that normal? Does that mean I need to re-pack with grease?
  19. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Yeah you can.
    You will need to remove the two bolts holding the TO stop the the back of the gearbox housing, and then slide the TO off the slave cylinder.
  20. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    #70 ernie, Sep 14, 2010
    It looks more like clutch dust mixed with break fluid.
    You will really need to have a look inside the bell housing/pumpkin to check for grease coming from the flywheel.
    But like I said, to me I looks as though it's clutch dust & break fluid.
  21. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #71 AceMaster, Sep 14, 2010
    I just had another closer look, and it looks perfect to me. Here are 2 pics, but I actually stuck my head right in there and did a 360 degree inspection, and it is not blown out anywhere. The only thing I saw was the grease along the bottom, which easily wiped off with a rag.
    Also, the bearing on the inside of the TO spun freely only when I used my finger, and as soon as I stopped spinning it she stopped dead - should it continue to spin freely and then come to stop slowly on its own?
  22. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #72 AceMaster, Sep 14, 2010
    This is the one I meant.
  23. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,269
    Andrew
    #73 NeuroBeaker, Sep 14, 2010
    I was looking at this one... edited in green to highlight the areas I was wondering about.
    All the best,
    Andrew.
  24. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Two more things before I call it a night:
    1) There was absolutely ZERO fluid that leaked out when I removed the bell housing, I was under the impression that some brake fluid would seep out. That wasn't the case.
    2) I just had a look at the triple seals - are those supposed to be on tight, or at least snug? If so, I am in trouble, because they are loose. There is nothing leaking from them, but if I push on either the top or bottom of them, the entire seal shifts.
  25. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    #75 AceMaster, Sep 14, 2010
    I think you just fixed the problem I was having :D:D. Now I can simply put it back together :)
    Joking aside, that is definitely the flash from the camera, the colour on that unit is uniform.
