Leak underneath clutch - help | Page 6 | FerrariChat
Discussion in '348/355' started by AceMaster, Sep 4, 2010.
  1. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,223
    Huntsville, AL., USA
    Andrew
    LOL! That's a pretty funny set of pictures. :D
    I actually went through the "Oh no......... whew!" going between them. :eek:
    All the best,
    Andrew.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    #127 ernie, Sep 22, 2010
    Coming along nicely Mike.
    That little hole on towards the bottom of the slave cylinder/flange, right above the seal, that is the weep hole I was telling you about. For the rest of you guys, if you look back at some of the other pics you'll be able to see that weep hole, from the out side. When you pull your clutch, if that weep hole has fluid coming out of it you know that your seal (the one Mikey is gonna be changing anyway, on the back side of the slave cylinder) has bit the dust. If there isn't any leaking then you don't have too fool with it.
    Another thing to do Mike, when you go to put those two little o-rings back on, go to a Honda dealer and pic yourself up a tube of Hondabond HT. Then put a dab of the Hondabond on your finger and smear it on the little o-rings before you put them back on. Be sure to leave the hole open, you just wanna coat the rings a little bit with the Hondabond. I did this when I put my box back together because it helps make a better seal once things are back in place.
  3. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    That's either one of the coolest Stooge tips ever or the motoring equivalent of a 'snipe hunt'! I'll have to google "hondabond ht" now. Nice one, Ernie!
    :D :D
  4. PAP 348
    Dec 10, 2005
    100,244
    Mount Isa, Australia
    Pap
    Honda bond is great stuff! :D:D
  5. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Great advice Ernie, thanks.
  6. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    #131 AceMaster, Sep 23, 2010
    Okay boys, yet some more work again today while I wait for my package to clear customs. I am hoping to have the parts tomorrow so I can get it all back together on the weekend, I really miss driving it and it feels like it has been FOREVER!!
    Anyhow, I just gave the Bush Support Flange and Rear Gear Inspection Plate a bath in brake fluid....almost as good as new.
  7. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    #132 AceMaster, Sep 23, 2010
    I found some rubber debris in the hole where that tiny O Ring goes behind the flange. I am thinking it must be some of the O Ring.
  8. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    #133 AceMaster, Sep 23, 2010
    So, it is time to break out Ferrari Especiale Tool # 09232010 (today's date :D:D) and clean it up...no, I am not a dentist, but I sure felt like one here :):)
    This dental pic/dental scaler is a handy tool, I advise anyone who does not have one to befriend a dental assistant and ask her to get you one of their boss's old ones :D:D
    Now you have to be VERY careful, I was EXTRA CAREFUL and was BARELY touching the metal, you do not want to scrape the metal in there otherwise there is a good chance you will not be able to get it to seal. So take your time, steady hands, concentrate, go soft and as soon as you feel metal let up. I would advise getting into a comfortable position first, that will help you keep your hands steady.
  9. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    #134 AceMaster, Sep 23, 2010
    For this procedure, I turned the dental pic sideways and simply scraped away as much of the rust/dirt/grease as possible - again, being VERY careful not to scratch the surface.
  10. PAP 348
    Dec 10, 2005
    100,244
    Pap
    You're doing good Mike! :D:D
  11. notbostrom
    notbostrom Formula Junior
    May 8, 2006
    957
    Orlando, FL
    Ben
    honda bond = yamabond if you only have a yamaha dealer in town. same stuff
    FYI
  12. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Thanks boys, the Brotherhood is out of this world.
  13. notbostrom
    May 8, 2006
    957
    Orlando, FL
    Ben
    #138 notbostrom, Sep 23, 2010
    and for you snarky italian machine owners.. Ducati bond is also the same stuff as hondabond and yamabond.
    Yamaha also sells an incredible cleaner. It is water based but will dissolve old gas that has turned to varnish in seconds. It's used to soak whole carbs without fully disassembling them. Will not eat rubber and is easy on your hands. Amazing stuff and I still don't know how it works but it does. It's cheap too..............
    http://www.yamaha-motor.com/sport/apparel/apscitemdetail/3/124/all/1/322/detail.aspx
  14. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Mike, I may have missed a comment earlier, but am assuming you verified the ring nut under the inspection plate is tight and staked down good? Just want to make sure. :)
  15. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Correct. I had a mechanic look at it, he grabbed it with his hand and twisted and tugged, advised me not to touch it as he feels it is fine the way it is.
    Thanks for double checking though ;)
  16. PAP 348
    Dec 10, 2005
    100,244
    Pap
    I would have still hammered that other side over man! :D:D
  17. mr308gtb
    mr308gtb Formula Junior
    Sep 12, 2004
    704
    MeestahBig
    awesome thread... when you put it all back together, can you specify torque requirements as needed... this is very complete so far. great job...
  18. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    I agree with Pap. Stake that other side down before you put the cap back on.
  19. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Ok guys, I will give it a try tonight.
    Ernie, I am going to give you a call to discuss this before I do...I may need to put on a pair of diapers for this as I am TERRIFIED of this procedure!! :)
  20. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    It's just a love tap to stake the right side of the ring nut a lil better. Nothing you need to put on a pair of Depends for. Though we have found a tiny foil hat can be helpful.
  21. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    #146 AceMaster, Sep 24, 2010
  22. PAP 348
    Dec 10, 2005
    100,244
    Pap
    Bah, piece of piss man. :D:D
  23. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    #148 AceMaster, Sep 25, 2010
  24. PAP 348
    Dec 10, 2005
    100,244
    Pap
  25. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    Looks like you knocked the dirt off it. I'm not even sure what I'm looking at. I'm assuming that those two sides keep what's inside from coming out. Is that right?
