Leaking 348 headgaskets | FerrariChat
Discussion in '348/355' started by Serpent Driver, Jan 16, 2012.
  1. Serpent Driver
    Serpent Driver Formula Junior
    Jul 4, 2004
    324
    Norway
    I have read numerous threads on leaking headgaskets from elring. What if you buy OEM gaskets from Ferrari? If they leak i guess you could demand a solution on this problem.
  2. plugzit
    plugzit F1 Veteran
    7,782
    Redondo Beach, CA
    Bruce Bogart
    Elring was an OEM supplier. Good luck with Ferrari doing anything about it. They may answer your call, but put you on hold.
  3. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    Same thing happened to me. All of them will tell you they never had any problem. Me and my friend Vitor have asked Ferrari, major suppliers in the UK and Elring directly. The first 3 never heard about it, Elring never bothered to answer (twice). But we know the problem is there.
    If you want my guess (but just a guess, no more than that) there must have been a defective lot and nobody wants you to know about it. So now we play Russian roulette ....
  4. Serpent Driver
    Jul 4, 2004
    324
    Norway
    Okei. What is different with the gasket now compared to when the cars where new? They where not leaking before. Material or complete design?
  5. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Contact Dave Helms (Fchat: davehelms). He is fully versed with the problem and I believe he has a solution. The OEM Elring headgaskets have been known to be problematic for years.
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,734
    The only way Ferrari would do anything about a failing new gasket is if their shop installs the gasket.
  7. fatbillybob
    Aug 10, 2002
    29,061
    socal
    and it will still leak but it is OK because we are Ferrari and we said so....
    Fixed it for you Mitch.
  8. Ricambi America
    Sponsor Owner
    We have sold about 6-8 sets since this 'issue' was posted on FerrariChat. None of them, when installed by professional shops have exhibited any leaking.
    If there was a defective batch from the manufacturer, it may have already been corrected and passed through the supply chain.
  9. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    hey Daniel, did any of those shops express differing the TQ sequence at all at install? in a post exchange with Brendan, he said an initial install and test (with oem elring gasket on 348 engine) showed leakage, but re-install with more 'steps' in torquing the head bolts (an attempt to limit head distortion) gave good results, thanks
  10. Ricambi America
    Sponsor Owner
    The same procedure has been described by the shops with which I've called for follow-up.
  11. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    do you mean going strictly by the manual, or to increase the number of TQ down steps?
    sorry, been a loong day, so my brain is on slow
    thanks
  12. Ricambi America
    Sponsor Owner
    Sequential torque with pauses in-between, then a final 90-degrees. Page B24 of WSM.
  13. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    interesting....thanks :)
  14. RGigante
    RGigante F1 Rookie
    Nov 1, 2006
    2,874
    Portugal
    +1
  15. Ferraripilot
    Ferraripilot F1 World Champ
    May 10, 2006
    17,856
    Atlanta
    John!
    I noticed in the Braden 348 thread that he applied some black silicone sealant to the head gasket. Is this common practice with the coolant passage areas on these heads?
  16. RGigante
    RGigante F1 Rookie
    Nov 1, 2006
    2,874
    Portugal
    Personally I wouldn't do it. I would be too afraid any of the silicone could enter the oil passages and obstruct them.
    The head gasket alone is supposed to seal. If it is not sealing, something is wrong.
    Just my 2 cents....
