Leaking exaust on 355 2.7 | FerrariChat
Discussion in '348/355' started by nice 348, Apr 22, 2011.
  1. nice 348
    nice 348 Rookie
    Apr 17, 2007
    5
    Gothenburg, Sweden
    Kenneth
    Hi!
    Anyone else having problem with leaking connection between the manifold and the Y to the valve?
    I´m not able to get it sealed and the pipe seem to short so the gasket end up half outside the pipe.
    I´m thinking of extending the pipe by welding, so the gasket gets a better grip.
    Have anyone had the same problem?
    Grateful for all assist.
  2. Tgreenshields
    Tgreenshields Karting
    Apr 3, 2010
    79
    Greeley, Colorado
    Tim Greenshields
    I might have some ideas for you......but allow me to ask:
    How do you know there is a leak....one side or both? How long has this been occurring? Have you tried repairing it previously.....? Did the leak or leaks start again?
    Tim
  3. nice 348
    nice 348 Rookie
    Apr 17, 2007
    5
    Gothenburg, Sweden
    Kenneth
    I can hear and feel the leak, it´s on the left side in the connection. It was leaking when I
    first mounted it, and I then remounted it with some exaustpaste and it was OK but after a
    couple of days and 200 km the leak is back!
    I´m now going to the garage to dismantle it again, then i´m thinking extend the pipe and also welding a ring on the connector for a certain sealing.
    If you any idea it´s welcome!
  4. Tgreenshields
    Apr 3, 2010
    79
    Greeley, Colorado
    Tim Greenshields
    When I installed the Fabspeed headers to my hyperflows and Capristo...the Fabspeed guys sent me new steel washers (4) and a new type of collar that works like a plumbing compression fit. They have worked really well so far.
    The problem you are having is that the header tube will not go far enough into the either the 2 cats or the 2 inlets of the muffler. You really have to push it all together and then tighten them quickly. I had to do this several times to get everything right. I loosened the muffler (Capristo) on the brackets so that I could push the pipes forward more, then went back and tightened the muffler brackets. Even a 1/4 or 1/2 of an inch is critical.
    Let me know how it goes and good luck.
