Leaking Fuel Sender | FerrariChat
Leaking Fuel Sender
Discussion in '206/246' started by djh4570, Dec 31, 2007.
  1. djh4570
    djh4570 Karting
    Sep 14, 2006
    118
    NewZealand
    Danny John Hayes
    #1 djh4570, Dec 31, 2007
    I have developed a petrol leak from around the fuel sender on my 71 euro which means its on the top of the drivers side tank
    (RHD because it was a Brit car) i should be able to get it out with out to much trouble HA HA HA but my two questions are
    1. Has anybody pulled a sender like this with out tank removal ?
    B. Is the gasket pictured also used on anything else ie Fiats ect if so what and a part number would be good ?
    Any help or just Sympathy glady received
  2. racerboy9
    racerboy9 F1 Rookie
    2,650
    It is a Fiat part. I think Dennis McCann has them. Check his site.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Dave (aka DM) has put a lot of effort listing several Parts Sources for us in a sticky thread at the very top of the Dino section
    http://www.ferrarichat.com/forum/showthread.php?t=106045
    I'd suggest trying reputable retailers as Ricambi, Rutlands, DinoParts.de, and Superformance - in that order
    I've pulled the sender without removing the tank from my Euro 246 GTS which has the sending unit mounted on the passenger's side fuel tank. Remove the six cap screws and pull the assembly up at an angle.
    POINT #1: not all Dinos have the sender on the same side tank - many have it on the Driver's side fuel tank
    POINT #2: Orientation is critical. Be careful when re-installing so that the sending unit goes back into the tank at the exact same mounting holes.
    I inherited this problem from a Previous Owner (PO) who had rotated my sending unit clockwise by one screw hole. The float at the end of the arm would hit the tank wall preventing any lower readings and the dash gauge would be pegged at half a tank for the last half tank.
  4. dm_n_stuff
    Dec 10, 2003
    43,753
    26.806311,-81.755805
    Dave M.
    YUP.
    Dennis McCann www.allferrariparts.com
    101462 FUEL LEVEL SENDING UNIT GASKET, (FIAT # 992273)(OLD # 820925) $12.00
    Should be in stock.
    DM
