Leaking power steering reservoir on 6.0 | FerrariChat
Discussion in 'LamborghiniChat.com' started by cafebisque, Apr 14, 2008.
  1. cafebisque
    cafebisque Karting
    Aug 19, 2006
    50
    Denver, Colorado
    Alex G
    Well,
    Here is the first mechanical expense to date out of my pocket. The last trip cost $4k, but was covered under extended warranty that cost $4k. So I am even for now. Anyhow, my power steering reservoir is leaking, so the tech thought to try to reseal for the second time. The warranty will not cover that specific part!!
    After 20 miles it has not leaked, but I guess eventually it will. I am being quoted $1600 for a new one. Does that sound about right? What's involved in replacing it? Would it qualify as a DIY job?
    If anyone has experienced something similiar, let me know of your results.
    Great appreciated!
    Alex
  2. 512lover
    512lover Formula Junior
    Nov 2, 2005
    262
    So. Cal
    If you don't mind me asking, but what was wrong that caused you to go on that first trip, and possibly $4K?
  3. cafebisque
    cafebisque Karting
    Aug 19, 2006
    50
    Denver, Colorado
    Alex G
    Here goes.
    The driver's door power window motor went out. Needed replacement. Right rear shock was not responding, so an error light kept coming on. Fuel door sensor mechanism was not working and there was a leak that turned out to be the power steering reservoir. Everything was covered except the reservoir, so the tech(Todd) tried to reseal it twice at this point. So far so good.
    Alex
  4. whart
    whart F1 Veteran
    Honorary Rossa Subscribed
    Dec 5, 2001
    6,554
    Austin, TX
    William Maxwell Hart
    I don't have time for a detailed reply, but the p s and the front lift system are tied together. The seals on the shocks also fail and the factory replacements at close to 2kdollars per will also fail, and have no warranty. The suspension system is the weak point of these cars. There is a guy that rebuilds the shocks and warrants them for about half the cost of the factory replacements. Or, you could simply replace the entire system, at some cost. But, if you experience repeated shock failures (including the electronic sensor in the shock, which as far as I know, nobody can rebuild or replace short of buying a new shock), you will eventually spend what it takes to replace the entire system with a more robust one.
  5. Auctung
    Auctung Karting
    88
    in my Diablo
    nun ya biznas
    sounds alot like my first visit to the service deptartment
  6. Auctung
    Auctung Karting
    88
    in my Diablo
    nun ya biznas
    I got mine rebuilt for $500 each and better than new
    new they are 2k, and will break again and again :(
  7. cafebisque
    cafebisque Karting
    Aug 19, 2006
    50
    Denver, Colorado
    Alex G
    Thank god for the warranty. I bought it for 4k from Lambo of Denver for 3 years, effective 12/1/07. It's pretty comprehensive. So the $4k first service total was actually completely covered by Toyota (that's who the warranty is thru). I was even money after that. Cost me only $50 deductible out of pocket. It's just that the warranty did not cover the reservoir which frustrated me.
    So back to the part in question. Is the replacement of the reservoir a DIY, or is it a dealer job only? And, is $1600 truly the cost of that part? Is there a cross to another manufacturer, such as Nissan perhaps?
    Thanks again,
    Alex
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Depending on your skill level and resources everything is a DIY job.
