leaking water | FerrariChat
leaking water
Discussion in '308/328' started by Alpo Marzoppi, Jun 6, 2010.
  1. Alpo Marzoppi
    Alpo Marzoppi Rookie
    May 3, 2010
    7
    Natal South Africa
    Alpo Marzoppi
    my car 308qv
    leaking water from the breather pipe water no over heat
  2. lightning
    lightning Formula Junior
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    I read somewhere that this can happen on the 308 when it gets hot, and you park up and leave it.
    It was a long term test of a Ferrari 308 GTSi Quattrovalvole published in a US magazine called "Inside Line" (Jun 15th 2007)
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    Either the water level is too high or you need a new cap because the spring is old & weak.
  4. TAZIO42
    TAZIO42 Guest
    Feb 12, 2009
    69
    CT
    Dan
    By breather pipe do you mean the tube that runs from the expansion tank down near the left rear wheel?
    If so, I have that same issue with mine if I drive for a while. A few drips, nothing significant. Just had a recent major service and assumed that they overfilled it when they replaced the fluid. Hoping it will stop after it has had a chance to equalize.
    Kind of ironic as all the old oil leaks are now gone!
