News
Leaky washer pump - suggestions?
Discussion in '308/328' started by Paul_308, Jun 9, 2009.
  1. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,335
    #1 Paul_308, Jun 9, 2009
    My windshield water pump leaks where the metal motor is crimped to the poly plastic housing just under the washer solution reservoir.
    Anyone have suggestions of a silicon goop or other quick fix to slow the leak, no pressure involved but the container won't stay filled but an hour. Doubt if epoxy would adhere to the polythene. I don't expect perfection, guess I could refill each morning I expect to use it until I can find a permanent solution.
    Or does anyone know of an alternative pump/reservoir. Last year MrSweden posted a nice reservoir/pump alternative but I can't find what he used.
