leather care for garage queens | FerrariChat
Discussion in 'Detailing & Showroom' started by ttforcefed, Sep 29, 2018.
  1. ttforcefed
    ttforcefed F1 World Champ
    19,256
    t has occurred to be that i have probably over serviced my cars as well as over detailed. So now after 20 years i have a good sample of new cars i bought 20 years ago as well as newer cars and with conviction i can say there is virtually no point feeding leather more than annually for a climate controlled garage queen. I have a few cars that have all cohabited in the same facility for the past 11 years and you cant tell the difference between the car that has been feed twice a year versus the car that has been fed once every 3 years. they're all ferraris around the same vintage.
    for those of you who have climate controlled garage queens, how often do you clean/feed your leather?
  2. S-T48
    S-T48 Formula Junior
    575
    Stevenson Ranch, CA
    Curious to know what is that garage queen?
  3. energy88
    energy88 Three Time F1 World Champ
    32,194
    West of Fredericksburg, VA
    I think the real measure of leather preservation is probably the amount of exposure to UV and sun light. If all your cars are driven about equally and also spend the majority of their time indoors, then your observation is likely confirming that leather feeding is more exposure related than time related.
  4. AClark
    AClark Formula Junior
    315
    I use Lexol conditioner twice a year with good luck.
    Most are modern cars , no vintage at this time.
    I agree with the other posters, amount of time in direct sunlight probably does more damage than being parked inside of climate control environment.
  5. ttforcefed
    19,256
    almost 2 dozen of them - pretty decent size sample
  6. rob
    rob F1 Rookie
    May 22, 2002
    4,284
    Vt
    I do the leather before the car goes into storage which is usually around November then when I take it out of storage usually around may I do the leather again and then usually once during the driving season. I use both cleaner an conditioner every time I do the leather.
  7. Kruegmeister
    Kruegmeister Formula Junior
    519
    Michigan
    Kruegmeister
    One more Level of Leather Protection for a Garage Queen is Humidity.
    Being in Michigan I run a Heater in my Garage for Winter which can Build Humidity. So I bought a DeHumidifier because Humidity is bad for the Frames on my 64 & 68 Corvette.
    But during the Research of "What Humidity Level" to keep it at, I had read that too low is Bad for Leather. Ideally it should be around 45% Humidity or Your Leather can "Dry Up"
  8. Partycrasher
    Partycrasher Rookie
    Mar 4, 2017
    17
    leaving the windows open a touch helps to more air through the car and not allow a lot of moisture build-up. a quality car cover is a plus.
  9. Qksilver
    Qksilver F1 Rookie
    4,553
    PC, UT
    Joe
    Leatherique annually seems to be sufficient in my experience.
  10. sandreb
    sandreb Karting
    Feb 7, 2018
    52
    Sander B.
    I like using Adams Leather Conditioner. It leaves a nice satin sheen and no greasy feel.
  11. spike308
    spike308 F1 Rookie
    Nov 8, 2003
    4,714
    Austin TX!
    Mike Z
    care to share some pics??
    mikesufka likes this.
  12. ttforcefed
    19,256
    Of the cars? There all over the respective sections
  13. mikesufka
    mikesufka F1 Veteran
    7,766
    Crosslake, MN
    Mike Sufka
    Would love to see your collection - I realize that’s asking a lot ...
    MDS
  14. Rossocorsa1
    Rossocorsa1 F1 Veteran
    May 14, 2017
    6,217
    I admit it, mine are total garage queens. I do the leather once a year, coincidentally every January. Because they are in a climate controlled environment and have limited constant exposure to UV, I don’t tend to do anything intense. I used to use Connoly Hide Care, but now, given that the leather is very clean, I simply do a spray rub of either Griots or McGuires. Both are very easy to apply and the scent is short lived.
    Flyingbrick242 likes this.
