Leather cleaning? Not just conditioning | FerrariChat
Discussion in 'Technical Q&A' started by Brian qv, Dec 1, 2004.
  1. Brian qv
    Brian qv Rookie
    Dec 28, 2002
    35
    Folsom, Ca
    What is good to clean the leather center console and door panels? I need to also get into the seams. I have and '83 308 with tan leather. At least I think it is leather. It looks very dirty. Should I just use a brush and a little soap and water, and finish up with some leather conditioner? What products do you recomend and how do I apply it. Thanks for the help.
  2. Oengus
    Oengus F1 World Champ
    #2 Oengus, Dec 1, 2004
    I used some leather cream / cleaner from Zaino and a soft bristled tooth brush for in the stitching area. Other than that the door panels etc. etc. is all elbow grease. The apply your conditioner. All it takes is a little time and some TLC.
  3. f355spider
    f355spider F1 World Champ
    18,044
    I have found any number of products to work well, from saddle soap to the Leatherique "prestine clean". Just remember that with any of them, one must be gentle and use the least amount of "agitation" to the leather surface as possible. I have found that all of them will lift some of the dye if you are not very careful...at least with old leather...that is, over 15 or more years old.
  4. cal355
    cal355 Formula Junior
    Jun 16, 2004
    383
    San Francisco
    Cal
    Try leather products from Lexol.Use on my F355 Spider.Protects from UV and keeps leather from drying out.Two stage system,cleaner and protectant.
  5. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    Have used and like Skidmore's leather cream.
    It is a cleaner and conditioner in one. After a few treatments the leather will be supple and smell like new--brings new life to old leather.
    Put it on at night and buff-off the next day.
    www.skidmores.com
    Mark
  6. TCM
    TCM Formula Junior
    Nov 10, 2003
    552
    Tyngsborough, MA
    I personally use Lexol cleaner on my client's cars. Have never had a problem with it being too aggressive and can usually get everything off of the seats with no issue. Hope this helps.
  7. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
    Use Leatherique's Prestine Clean, with, as Dave says, very little agitation. I've used a toothbrush with very soft bristles and had incredible results.
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Usually when a cleaner is 'lifting dye' it's doing what it's supposed to: removing a layer of dead pigment to reveal fresh pigment. Just like polishing a car finish.
    I prefer to use Prestine Clean with either a microfiber cleaning cloth (grocery/hw store) or a terry cloth (detailing towel or washcloth).
  9. steveirl
    steveirl Formula 3
    Dec 29, 2003
    1,163
    ireland
    steve
    I use Gliptone liquid leather cleaner available from www.liquidleather.com or also found Autoglym leather cleaner excellent and probably easier to get as it is stocked by auto parts stores. Whatever you do dont use soap and water, and definitely do not use saddle soap, it should only be used to clean equestrian wear, which is not dyed, it is very harsh and meant for cleaning dirt and salt from leather saddles, boots etc, not car seats.
    steve
