355 - Leather Trim Panel Removal? | FerrariChat
355 Leather Trim Panel Removal?
Discussion in '348/355' started by Laserman, May 10, 2022.
  1. Laserman
    Laserman Karting
    Oct 26, 2018
    113
    Minneapolis, MN
    Does anyone know how to remove these 3 leather trimmed panels for leather replacement in a GTB.
    I have spent too much time trying to figure out the trick and I do not want the break something.
    Keep in mind that my car is a Canadian version
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    They unscrew from the engine compartment. A few posts cover it but if you look you'll see it by the cross compartment rad lines.
    phrogs and ShineKen like this.
  3. Laserman
    Laserman Karting
    Oct 26, 2018
    113
    Minneapolis, MN
    Thanks , Eric.
    I assume the center one need to come out first.
  4. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Center one out first the ones on the corners are more tricky. They are secured with screws visible once center is removed and in the corners a nut is holding it behind the door rubber gasket, tucked up under the leather cover.
    Mike Morrissey and ShineKen like this.
  5. Laserman
    Laserman Karting
    Oct 26, 2018
    113
    Minneapolis, MN
    Thanks, guys.
    I got them out.:)
