Leatherique Color??? | FerrariChat
Discussion in '308/328' started by Tifosi100, Feb 1, 2015.
  1. Tifosi100
    Tifosi100 Karting
    Sep 26, 2006
    52
    Montana
    I was wonder what Leatherique color is the best match for a tan interior - My car is a 1980 GTSi - interior is "typical" tan color - red exterior - I know - rare and unique right? Thanks in advance - Nick
  2. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    typically you send leatherique a small sample and they color match it
  3. bigodino
    bigodino F1 World Champ
    13,127
    The Netherlands
    Peter den Biggelaar
    I'm having my tan interior re-dyed right now and the leather guy said he has seen many different shades of Ferrari tan pass through his hands. From his experience there's no typical tan.
  4. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    this
    you might cutt off a small piece from under your seat - that is the place where your tan color is probably the most original
  5. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,124
    Atlanta
    Tom Spiro
    Here is the issue with taking a leather sample ... if you send them a sample of leather from under the seat they will do an expert match, but it will not look the same as the rest of the interior as your interior has a patina on it... so unles you are doing a complete trim redye ... try to get them to match the color with a hi res photo or tint it to match.
    I use leatherique - love the products & its a high quality product.
  6. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,599
    Gates Mills, Ohio
    Jon
    #6 Bullfighter, Feb 2, 2015
    Agree. This is a problem with re-dyeing vintage leather.
    Before I bought my (now ex) 328, the interior was ruined by re-dyeing, and I'm 99 percent certain it was Leatherique. Looked like absolute painted-on garbage. I don't know who did it, but obviously it was a DIY job. A previous owner mentioned Leatherique, which is why I think this was the product used.
    If you don't know how to refurbish leather, get a professional to do it.
  7. Rich S
    Rich S Formula Junior
    Nov 30, 2013
    501
    Monterey, California
    Rich Saylor
    There's another way: A good shoe repair shop can mix up leather dye to match whatever sample you bring in. The dye can be sprayed or painted on with a brush. Remove the seats and whatever else you want to re-dye, remove anything you don't want to dye (trim, hardware, etc.) and working on a clean table, the surface is prepared as follows: clean the surface with lacquer thinner (not paint thinner) using a soft rag, not soaking the leather but cleaning it carefully. Let it dry, then carefully brush or spray on the dye in thin, even coats, like three coats or so, not heavy coats. Let the dye dry between coats, this usually takes a few hours or overnight. After the leather is dry, you will probably see some uneven surface appearance here & there (different gloss) which is taken care of using Lexol; just use a soft rag to wipe in the Lexol, wipe it dry; a couple of applications might be needed. When it's dry the leather will look good!
    Please note that this is a surface treatment,which of course is never as good as the original finish of the leather, but if you take care of the leather it should last a while.
    The above treatment process was explained to me by a very experienced upholsterer, who does a lot of restoration work. I followed his instructions and it came out very well!
    Re brush vs. spray: Many hardware stores (like Home Depot) sell a small spray bottle kit (about $5!) that can be used to spray the dye, but in my experience the dye is too thick to use the small plastic filter screen on the end of the pickup tube, so I left it off. Be sure to mix the dye very, very well, no lumps that will clog the sprayer. Otherwise just brush it on, and wipe of the excess. It helps to have the surface being dyed flat.
    For myself, I chose a darker tan color than original.
    However you do it, best of luck!
    Cheers,
    Rich
  8. spirot
    Dec 12, 2005
    15,124
    Atlanta
    Tom Spiro
    Well, I've done my seats before in two cars - once with out Leatherique and 2x with and the results have been great - not by my standards but by peoples reaction to - wow your seats look great... kind of thing.
    its never going to be new looking - but if you use proper prep and take your time, they will come out great. The hardest part is to go slow and be methodical. sanding down the old dye, and using the prepping agent takes time ... but I've found it to be a great solution.
    the stitching is the stumbling block - you will most likely go over the stitching and you have to be careful to not build up "gunk" in the stitching.... I like the scumbling method - painting leaves marks, and airbrushing takes FOR EVER... you have to build up layers just like the old masters did when painting.
  9. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Typical gtsi tan = Ferrari Beige = Connolly Saddle 3218 = Leatherique 2111255.
    Best...Jim
  10. Tifosi100
    Tifosi100 Karting
    Sep 26, 2006
    52
    Montana
    Thanks for the replies!
    2nd question - How much is typically needed to do the seats, doors, and console?
  11. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
