LED bulbs | FerrariChat
LED bulbs
Discussion in 'Boxers/TR/M' started by ago car nut, Mar 22, 2012.
  1. ago car nut
    ago car nut F1 Veteran
    5,506
    Madison Ohio
    David A.
    Where is the best place to purchase (quality) LED brake light bulbs? Single filament type.
    Ago
  2. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,603
    Pacific NW
    Anthony C.
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    #3 Melvok, Mar 23, 2012
    I am renewing all the bulbs in the back of my 512TR this week ... with "normal" ones ... :)
    The orange paint is coming off partially ...
    Prices of LED lamps are frightfully high over here ... two 21 watt LED lamps $ 15 or more
    And we need 12 ........... and what is wrong with these lamps .......
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Led replacement lamps are getting better. Be aware that if you are replacing blinker lights that you may need extra resistance (resistors) and or a different flasher relay. I have found Ebay to be a very good source of LEDS. A few thoughts: matching LED color to lens color doesn't always work as well as using white LED color. Depends on the filter color of the lens and the emission wavelength of the LED. Be aware of length and width of LED and if it will fit behind the Lens. Also, many of these LED replacement bulbs are built up and then different bases are put on the same LED bulb hence they can fall apart while installing them, lesson here is to buy spares or seal the bases well before use. Hope this doesn't turn you off from the use just be cautious. Good luck! Superbright is good to deal with.
  5. Steve
    Steve Formula Junior
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    For the benefit of anyone stumbling across this old thread via a web search (and because the manual is WRONG), I've put together a blog post with photos with all the bulbs (and the replacement relay) needed to convert the most popular exterior bulbs on a 512 TR to LED:
    How To: Replace Ferrari 512 TR Bulbs with LEDs - SteveJenkins.com
  6. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    eBay....I did....
    Few words Me
