LED bulbs | FerrariChat
LED bulbs
Discussion in '308/328' started by vito11, Jan 12, 2022.
  1. vito11
    vito11 Karting
    Oct 8, 2006
    155
    In the Ferrari 328 dashboard there are 12 units of medium bulbs type bulbs 9 mm. 4W, Ref. Silvania 3893, Philips 12929 and 10 units Type Small Bulbs 5 mm. 1.2 W Wedge Type, Ref. Silvania 2723, Philips 12516. Wanting to replace all these units with LED bulbs Do you know what type of LED purchase?
    I ask for the final solution.. Many thanks.
  2. Sigmacars
    Sigmacars Formula 3
    1,218
    You can find all the bulb type in your manual
    That number you can use for cross reference for the led,s on e bay I change all of mine plug and play big difference
  3. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    #3 lm2504me, Jan 13, 2022
    I have a 1978 308:
    Keep the incandescent light bulb for the alternator low voltage warning. A diode is inline to bulb. When the battery output is more than the alternator output the bulb illuminates. (Should be still valid for 328 based on wiring diagram)
    I had to purchase a LED flasher relay 3 prong and add a ground connection to my relay board for the additional prong on the flasher relay.
    The bimetallic type would not work due to lower current draw.
    328 uses a three prong flasher per wiring diagram. It would need a LED flasher module for outside LED turn signal lights and the turn signal lights in the dash.
    I purchased most of my LEDs from SuperbrightLED website.
  4. vito11
    vito11 Karting
    Oct 8, 2006
    155
    Many thanks.
  5. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    #5 lm2504me, Jan 15, 2022
