LED Light | FerrariChat
LED Light
Discussion in '348/355' started by David P, May 13, 2011.
  1. David P
    David P Rookie
    Jan 28, 2010
    28
    Texas
    David P
    I have a problem with my 355 and wanted to know if anyone else has had the same problem. When starting up, the LED light comes on for a few seconds, flashes off, then stays on for the duration of the drive. I know it comes on if the door, hood or engine cover is open, but I have checked those and they are securely shut. Am I missing something else? Any advice would be appreciated!!
  2. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Dave:
    Exactly what LED light are you referring to?
  3. David P
    David P Rookie
    Jan 28, 2010
    28
    Texas
    David P
    The LED light that is part of the theft system located between the vents in the center of the dash. The owner's manual indicates that it should go off unless it senses that a door or hood is open, and mine is staying on even though the doors and hoods are securely closed. I didn't know if this is a typical issue with the 355 that could be easily remedied or if I should plan on a dealer visit. Thank you.
  4. dougburhyte
    dougburhyte Karting
    Dec 28, 2005
    166
    Douglas Burhyte
    Hi David,
    I had a similar problem with mine and it turned out that the alarm module's battery was no longer functioning at required level. Replaced the alarm module and problem went away. I recall some past posts that suggested one could replace only the battery if they were a bit handy, but I don't recall what the replacement battery size or spec was. Hope this helps.
    Doug
  5. f355spider
    f355spider F1 World Champ
    18,055
    +1. David, do a search for "355 alarm battery" and you will find a few threads with tutorial for replacing the battery in the alarm module.
  6. mwhitesell
    mwhitesell Formula 3
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    Mine did exactly this when the regular car battery was low. I changed the battery and havent seen it again.
